what is the stiffest shocks
  • skatefreak
    • Jan 2006
    • 116
    I have tokico Illumina adjustable shocks but I only have three. I need a set of rear set that is very stiff. or a place to buy a tokico illumina rear. someone help.
  • Jordan
    • 12916
    Tokico = garbage.
    https://mtechniqueabs.com/
    • asubimmer
      • 6482
      stiffer is not always better
      • skatefreak
        • Jan 2006
        • 116
        I know stiffer is not better but I have wheels with bad offset and they rub so I want to either stiffen up the rear instead of flares. Tokicos worked great on my ITC Datsun 510 for over three years.
        • 808BMW
          • 2910
          Wouldn't stiff springs help with that problem?
          I don't know how stiff shocks effect soft springs (I've never tried it), but it wouldn't seem to overcome a ride height problem.
          • skatefreak
            • Jan 2006
            • 116
            I have IE stage III's
            • 92 mtechnic cabrio
              • 4907
              it wouldn't raise the car, it would keep the car at the same height, and the tires just wouldn't rub because the car wouldn't squat down in the rear as much with stiffer shocks.
              R.I.P 07/01/09 - 04/23/10 :(
              • Scott314
                • Jan 2005
                • 287
                What wheel/tire combo are you running, and what offset are your wheels?
                My fast says: traction control is for the faint of heart :evil:
                • skatefreak
                  • Jan 2006
                  • 116
                  205/50/15 with et20 offset plus adapter
                  • E30-323ti
                    • 328
                    Originally posted by 92 mtechnic cabrio
                    ...and the tires just wouldn't rub because the car wouldn't squat down in the rear as much with stiffer shocks.
                    Not true, stiffer shocks will just react slower with stiffer bump and/or rebound.
                    But if you have stiffer shocks then you can run stiffer springs which make the suspension compress less for a given load (bump) which will reduce rubbage.
                    But if you hit a big enough bump they will always rub!!
                    I presume the arches are already rolled & pulled if you are thinking about flares!?!?!
                    292rwhp E30 :D
                    • skatefreak
                      • Jan 2006
                      • 116
                      yes they have been pulled and rolled, the only other thing would be to stretch the tires, which would be horrible so.... But I have a set of BMP/IE's bubble flares.
                      • Dave
                        E30 RAT
                        • 11675
                        Originally posted by Jordan
                        Tokico = garbage.
                        Funny thing is, in some circles, konis and bilsteins are considered garbage.
                        Not to say i disagree with you, J. I have not heard much good about Tokicos in an e30 application. I know some Toyota and other people swear by them.
                        Current Cars
                        2014 M235i
                        2009 R56 Cooper S
                        1998 M3
                        1997 M3
                        • skatefreak
                          • Jan 2006
                          • 116
                          so does anyone actually have an answer?
                          • parkerbink
                            • Jun 2004
                            • 10138
                            How does good for a certain car mean good for another? I had Tokico on my 300 ZX and I hated them, they had been suggested by my mechanic (who I spent a fortune with) He replaced them (free for the differance in price) as he wanted to keep my future business, with Konis.
                            You can't just change one part and expect good results. You need to get springs/shocks made to work together for the purpose you need to fulfill.
                            Seems to me you need different rims/tires not springs/shocks.
                            • 1991 318is
                              • Dec 2005
                              • 786
                              [imo][/imo]
                              [IMO]You have a wheel problem, not a shock problem. Solve it with wheels.[/IMO]
