m3 rear hubs
  • franken325i
    • Jan 2013
    • 78
    m3 rear hubs
    i was wondering if anyone knew were to get new e30 m3 rear hubs. ive been looking around and cant seam to find any. im trying to gather parts for a 5 lug swap and i want to just put m3 hubs in my non m3 rear arms.
    • 37829
    Buy them from BMW.
    The part number is 33412225510
    They are $150 each at TheBMWpartStore.com
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • dirtbykerhst
      • 12
      Frankie, I have e36 ti hubs that will work. They are complete with hubs, bearings, brakes, etc... $200. Contact Mike @ 330-321-7115. I could deliver 1/2 way to NY or ship them.
      • Gooch
        • Dec 2006
        • 1674
        Do you already have the rear calipers and carriers? Before you buy the hubs don't forget you need the rear brake components also.
        '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
        '87 535i - Vacuum brake conversion [SOLD]
        '93 525iT - 5-speed swap - 320k and counting
        '09 328xi - 6-speed
        • FredK
          • 14761
          Yes, the only source of M3 rear hubs is through BMW. The rear discs are slightly larger, so you may want to get M3 brake backing plates. You might be able to run your stock backing plates with a little trimming, but I'm not sure about that.
            • 37829
            You can use the non-M backing plates. A little different but they'll work.
            Grover Beach, CA
            www.BimmerHeads.com
            • franken325i
              • Jan 2013
              • 78
              ok thanks guys and no i dont have the brakes yet im still creeping around local junk yards im in no rush as of yet. thanks for the info, Harry
              • RobE30
                • 959
                Will any other rear brakes work or must they be M3?
                09 BMW 328xi touring 6spd
                05 Subaru Outback XT 5spd
                87 BMW 325is
                a few bicycles
                • Holland
                  • Nov 2008
                  • 7212
                  I thought M3 rear hubs didn't work in non M trailing arms? I know the front is bolt on.
                  Originally posted by DEV0 E30
                  • FredK
                    • 14761
                    The trailing arms are identical between the M3 and the non-M, rear disc brake E30. If you get the rear hubs, brake backing plates, and rear brakes and carriers, the setup is now the same as an E30 M3.
                    • Holland
                      • Nov 2008
                      • 7212
                      So why do people bitch about 5 lug swaps then? Sure it isn't that cheap but easily accessible. Aren't the rear calipers between an E30 M and an E32 interchangeable anyway?
                      • FredK
                        • 14761
                        The rear calipers are shared with an E32, but the caliper carriers are an E30 M3-specific part. They at least used to be NLA, but it seems you can order PN 34212226876 at around $135 each. They definitely *could* be backordered, so you'd have to check with an OE BMW parts dealer for specific parts availability either here or in Germany. I think years ago someone found you might be able to open up the disc slot of a 318ti brake carrier to accomodate the E30 M3 rear disc rotor in order to save money, but I'm uncertain if this was ever confirmed.
                        It's definitely not out of reach, nor is it particularly super expensive to retrofit E30 M3 parts out back.
                        • einstein57
                          • Jun 2007
                          • 10780
                          318ti/z3 caliper carriers will work but the pad does not quite properly position the pads on the rotor. To far out IIRC.
                          www.gecoils.com
                          • pandaboo911
                            • 2070
                            I've been told that e36 non m hubs are a direct fit on the e30 trailing arm. I have a set and will try to confirm if they fit, they are a lot cheaper than the m3 hubs, and retain the same offset unlike 318ti hubs
