Coilovers - Converting your strut tubes
  • Blackout
    • Apr 2011
    • 4130
    Originally posted by IronFreak
    Thanks man, spread the word. Me and a few buddies are getting a shop in the next month. I'd gladly do some of these at a discounted rate for the community to help pay rent!!
    R3v needs more skilled assets like you :bow:.
    » PARTS FOR SALE
    » TRANSACTION FEEDBACK
    • IronFreak
      • Dec 2012
      • 3702
      Hahaha, thanks man. I absolutely loving doing this stuff. If I wasn't in the Midwest but more on the coast like Cali....I would be bugging the crap out of Castro Motorsports to let me work for them hahaha.
      I just put these beauties together this weekend with a little help from GC!
      Instagram @rebellionforge
      • acolella76
        • 2950
        me likey
        -Alex
        • DRTSRFR
          • May 2008
          • 1836
          Aaaaaand where are your bumpstops?;)
          Looks great by the way!
          Suspension tips here...
          http://www.r3vlimited.com/board/album.php?albumid=757
          • IronFreak
            • Dec 2012
            • 3702
            I was actually looking for some today.....you wouldnt happen to know anyone that sells them would you?
            • DRTSRFR
              • May 2008
              • 1836
              I've got them here for $12 each. Made specifically for GC in Europe.
              Very high quality, and available as progressive so no harshness if you get into them.
              • IronFreak
                • Dec 2012
                • 3702
                I was just looking at those, with the Koni adjustables, and spring rates at 525 which one's would you recommend?
                • DRTSRFR
                  • May 2008
                  • 1836
                  Soft progressive
                  • IronFreak
                    • Dec 2012
                    • 3702
                    I'll make sure to get some of those on the shocks before final installation. Thanks!
                    • kingston
                      • Jun 2010
                      • 2669
                      For that price, I think I will pick up a set, too!
                      I've still got at LEAST another 1.5" I could go down front & rear in the pic of my sedan that Ross posted. That photo was also taken pretty much immediately after installation, so the springs hadn't really settled at all yet.
                      REALLY happy with the work Ross did - I'll be throwing more business his way soon!
                      Originally posted by LJ851
                      kingston is the play by play announcer for this thread.
                      ‘Tis by the grace of God that my cars run!
                      Originally posted by unloadedak
                      #teamross
                      Siobhan's Build Thread - UPDATED!
                      • butters
                        • 1202
                        Bumping this thread bc it's relevant to something I'm pondering.
                        I just got Koni SA shocks, but now I think I should pull the trigger on the GC adjuster kit.
                        After some brief research, including this thread, it seems the Koni yellow is the "standard length" strut i.e. same length as stock which is why you didn't need to shorten the strut housing.
                        Does this have any major drawback? kingston - are you bottoming out?
                        I'm wondering if I should be looking at swapping my Konis with some from GC or if I'll be okay. Street use car mainly, not looking to be excessively slammed just set it where I want it on 17" wheels.
                        • IronFreak
                          • Dec 2012
                          • 3702
                          I'll let Kingston reply as well but I would say get some good bump stops and run what you got. you are correct though, they are stock length. if you want the shortened ones I believe it's the IX shocks you need the e30 strut tubes. I went 5-lug which are already shorter then e30 struts.
                          This is the same car after settling a bit. if you look at his post above you can see he still has room to play. I can;t answer the bottoming out question though.
                          • butters
                            • 1202
                            His car looks pretty damn low, and I am not one to uber-stance out my cars. I just feel that with Kopi 17" wheels I could use a bit more of a drop than the ST springs I have now to make it look right. I'm also looking at getting away without the camber plates, for now anyway. I suppose the plates give a bit of extra travel in case I grow frustrated.
                            • IronFreak
                              • Dec 2012
                              • 3702
                              I don't think you have to use camber plates. GC kits come with spring hats to where you could probably put the stock e30 hat on top of that. Especially if you're not going stupid low, it would probably be ok.
                              • Balleristic31
                                • Aug 2009
                                • 4198
                                Where did you get the adjusters posted in the op?
                                -NICK
