Ground Control coilover conversion kit question
  • Chofin
    • Jan 2013
    • 51
    preferred shocks to use?
    spring rate suggestions for a car that is mostly a dd (besides some spirited drives from time to time), some auto x might be in to future.
    whats the normal complete price including shocks?
  • Lodsin
    • Sep 2006
    • 734
    I think Eibachs are the regular pairing. But for what you're getting into why coil overs?
    • Chofin
      • Jan 2013
      • 51
      ive been told i would be happier in the long run. if you have any suggestions of some solid spring/shock combos feel free to suggest. Looking to get the car somewhat low
      • AndrewBird
        The Mad Scientist
        • 11898
        IE Stage 3 springs + Bilstein Sports are a great setup. H&R race springs are the same springs. Unless you want to go really low or be able to adjust your ride height at will, there is no need to get coils.
        • Chofin
          • Jan 2013
          • 51
          which goes lower? the IEs or the H&R race springs?
          • Herr Faust Schinken
            • Feb 2012
            • 3580
            they lower about the same, they are almost the same spring (same rates) just made by different companys
            88 325is Five Speed
            Lachssilber
              • 34844
              IMO, the biggest reason to do coilovers is you can swap out your rates to basically anything you like. If you start out as a DD only you can start with softer rates. decide to track it, pick up some inexpensive used springs in the rate you like and swap them on with basically the same suspension.
              but, bolt in kits work well and they're simple. just less flexible.
              • Chofin
                • Jan 2013
                • 51
                thanks for the help, i think im going to go with the billy sports and ie stage 3s/ h&r race. just whatever i can find cheaper
                • SirSwag
                  • Oct 2012
                  • 127
                  Go with ie3 they are very good springs imo
