lowered issue
  • kusserwagon
    • Dec 2012
    • 43
    lowered issue
    So I recently installed JOM coilovers, and brand new tie rods, control arms with bushings and ball joints. I have it lowered all the way and now my steering rack is contacting the passenger side control arm at almost full turn. Anyone else run into this? Can I add some spacers were the steering rack mounts to the sub frame for some clearance? (I haven't been underneath it to see since I just found the problem after work today)
    And just for reference, I'm not sitting that low. My front tire is about a 1/2" from being flush with the fender (205-55r15).
    Thanks for any input.
    Also NO raising it back up is not an option. Im not trying to "stance" it or drop it on the ground, but im happy with were it's sitting.
  • mr ilia
    • May 2011
    • 582
    You may have outer tie rods that are not the same shape as oem.
    • kusserwagon
      • Dec 2012
      • 43
      i inspected the new/old tie rods side by side and they are the same shape, length, etc...
      • Jaxx_
        • Dec 2009
        • 1880
        Is it possible that you have left and right tie rods flipped? like you installed the right on the left, and left on the right? I don't think you should have any binding or contact of the suspension to tie rods even at full lock and compression.
        • F34R
          sLaughter
          • 12376
          Post some pictures with the wheel removed and a jack loading the suspension.
          Instagram: @BWeissLeather
          Current cars:
          ~ '87 325 M30B35 swap
          ~ '87 535
          ~ 01 540 Msport 6spd
          ~ '06 X5 4.8is
          • Cletonius
            • 2809
            They're not the same left to right? They look the same to me...
            - Josh
            1990 325is
            Need a shift boot?
            Looking to buy shift boot frames, PM if you have one to sell
            Here's what happens when you let the internet pick your license plate
            • IronFreak
              • Dec 2012
              • 3702
              The left side is the rights side and.........wait, that would make the right side the left side also......
              They're not side specific, so that's not your issue unless you ordered the wrong ones.
              Instagram @rebellionforge
              • IronFreak
                • Dec 2012
                • 3702
                what brand of tie rods did you buy?
                • kusserwagon
                  • Dec 2012
                  • 43
                  Yes im sure I have them installed correctly left and right. The tie rods and control arms I replaced are ATEC brand, made in Germany, bought off german amazon. (I live in Germany) And for technical reference, im also a mechanic so im not new to replacing basic parts. Im going to pull in over the pit at my shop today and have someone steer while im underneath looking at what I can do.
                  • CHIF8008
                    • 3447
                    never had an issue like this even being much lower than you. problem is on your end, hope a good visual inspection sorts it out
                    -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                    -The Beauty in the Tragedy-
                    MECHANIC SMASH!!- (you all know you do it)
                    Got Drop?? ;-)
                    But of course
                    E30s are know to be notoriously really really really ridiculously good looking
                    • Mr. Tasty
                      • Jul 2011
                      • 3421
                      they are identical, left from right.
                      2014 Alpine White 335i MSport
                      (Daily Driver)
                      Full Mperformance Aero
                      KW V2 Coilovers
                      VRSF Catless Downpipes
                      • Jaxx_
                        • Dec 2009
                        • 1880
                        sorry for my suggestion. I was thinking of tie rods from my other car that are shaped differently from side to side for clearance. I can't remember what the assembly for the e30 looks like, but basically the idea was that the C-shape portion of the tie rod I was thinking of could be facing inward instead of outward to provide clearance, or vise-versa.
