GC setup+front top camber plate requirement
  • Mr. Burns
    • Aug 2011
    • 3516
    well I absolutely did not do that.
    would it be advisable to try out koni adj. instead?
    I find it hard to believe that a bilstein sport would bottom out, especially at the ride height i'm at now...it doesn't seem feasable, it's not extreme or anything whatsoever.
    but there doesn't seem to be any other logical explanation
    the rear coilovers are much lower, and it's super smooth.
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
    • IronFreak
      • Dec 2012
      • 3702
      Look at it this way, Billy HD's are stock length so the housing doesn;t need to be shortened. when the suspension is loaded your sitting mid stroke on the shock. with billy sports its a shortened shock, so to make it ride in mid stroke you have to shorten the housing. Hopefully that made sense. So what I gather is happening, your running a billy sport, but inside a stock housing so you have to space up the shock so it locks in correctly. Problem with this is you are compressing the shock and when suspension is loaded your are riding at the very low end of total compression.
      Hellabad, feel free to correct me if I am wrong.
      What you have will work, but you need to shorten the housing to get the shock to ride at mid stroke. Billy HD's and Koni are stock length so you don't have to shorten the housing.
      Instagram @rebellionforge
      • IronFreak
        • Dec 2012
        • 3702
        Here are two links that explain what I am talking about a little better. The first is with Koni's. These are Kingstons. no need for shortening the housing.
        This is a thread on how and why you shorten the housing when using billy sports or billy ix shocks.
        • Mr. Burns
          • Aug 2011
          • 3516
          holy hell NICE fab work!
          thanks for all your insight and help, I think I've got my answer...and a top plate is not my issue.
          I'll likely be replacing the billstein sports with koni adjustables.
          • IronFreak
            • Dec 2012
            • 3702
            No problem and thank you!
            Let us know how it pans out.
            • ZekeTheSneak
              • 1562
              Shoulda bought Bc's. The limited short shock selection is why I will never go with ground control.
              • kronus
                • Apr 2008
                • 13032
                lol
                cars beep boop
                • Mr. Burns
                  • Aug 2011
                  • 3516
                  am I on the right path in thinking the proper koni SA strut to order would be 8641-1210SPORT?
                  cheapest I found is @ $137/ea+free ship here--> http://ltbautosports.com/aa158a.html
                  seems to be some confusion on the proper model...1210 or 1021?
                  • DRTSRFR
                    • May 2008
                    • 1836
                    Though dimensionally similar, the 1210 is for the 325 where the 1021 is for the M3.
                    Suspension tips here...
                    http://www.r3vlimited.com/board/album.php?albumid=757
                    • Mr. Burns
                      • Aug 2011
                      • 3516
                      therefore the 1210 is the go to Koni strut for a 400#f GC/eibach 5" spring?
                      • Northern
                        I like cupcakes & sh!tboxes
                        • 5284
                        When I was running h&r race with billy sports/ camber plates, the wheel gap was less than an inch and I would occasionally bottom out over huge bumps. I have a hard time believing that op's car is bottoming out so much.
                        Also, bilstein sports are designed for stock housings. The only difference from the hd's is that the sports will go a little lower.
                        Since getting ge coils, i've been considering shortening my housings and running a koni ix insert or similar for more shock travel.
                        But honestly, I wish I wouldve just bought a full gc setup from the beginning.
                        Originally posted by priapism
                        Originally posted by shameson
                        • Mr. Burns
                          • Aug 2011
                          • 3516
                          the occasional bottoming out I can live with.
                          when I take an onramp onto a 400 series highway with vigor and I'm banging and bouncing to the point it doesn't feel safe, I simply drive home, put the car in the garage, weep and take the Mazda 3 instead.
                          yes it's that bad.
                          • IronFreak
                            • Dec 2012
                            • 3702
                            I don't know what year your car is but here is where I got mine.
                            • IronFreak
                              • Dec 2012
                              • 3702
                              Sorry, but I'm almost 100% positive the sports are shorter then the HD's.
                              • Northern
                                • 5284
                                They will compress more, but they are made to fit the stock housing.
