Quick coilover question
  • slowturbo
    • May 2013
    • 47
    Hey Guys,
    About to place an order for some BC racing coilovers. THey have two different models, a 4cyl and a 6cyl. I assumed this was due to different spring rates, but apparently the 6 cylinder models have the 51mm struts. I have read that the 1991 318is has the 51mm struts, but does this apply to the 1991 318i? Just want to be certain which model to order. Thanks for the help.
    -Alan
    Current:
    1991 318i
    2011 328i
    Past:
    2002 325i
    2007 335i tuned
    2004.5 a4 1.8tq GIAC
  • e34_spangler
    • Dec 2012
    • 311
    Well Its news to me that there different if they are.. but I'd just order whichever engine you have.
    • IronFreak
      • Dec 2012
      • 3702
      As far as I know all strut tubes are the same (51mm) unless you have a M which is slightly smaller. I have done coilover conversions on 318 and 325's and I used the same parts for both cars.
      Instagram @rebellionforge
      • slowturbo
        • May 2013
        • 47
        They are not all the same. There are 45mm and 51mm sizes. I have seen conflicting statements regarding what size shocks late model 318i cars have. Any input would really be appreciated.
        -Alan
        Current:
        1991 318i
        2011 328i
        Past:
        2002 325i
        2007 335i tuned
        • FLG
          • Sep 2011
          • 3165
          Measure your stock ones.
          Sent from my Galaxy Nexus using Tapatalk 2
          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
          • slowturbo
            • May 2013
            • 47
            I would but do not currently have the car (it is at the shop) and would like to order these today. Has anyone here changed susp on a late model 318i? Please provide input.
            -Alan
            Current:
            1991 318i
            2011 328i
            Past:
            2002 325i
            2007 335i tuned
            • FLG
              • Sep 2011
              • 3165
              Why take a chance? Call the shop and just have someone crab a set of calipers and measure... I'll take 10 seconds.
              • IronFreak
                • Dec 2012
                • 3702
                From what I can tell it was very early "early" models that had the 45mm strut tubes. Out of curiosity......why does it matter? you're going to a completely stand alone suspension that comes with everything you need. If you were going to buy a GC coilover kit or new shocks I could understand your concern with the strut size.
                Not sure why it's a concern in this case.
                • FLG
                  • Sep 2011
                  • 3165
                  Iron the bc gets welded to the stock knuckle but must fit tight around what's left of the stock tube when you cut it so it's centered and such.
                  • IronFreak
                    • Dec 2012
                    • 3702
                    Ah that makes sense then. I have never looked into BC before I thought it was the whole setup.
                    • slowturbo
                      • May 2013
                      • 47
                      Yeah it seems all the 90-91 318s had the 51mm tube. Ordering those and will post back with updated photos!
                      -Alan
                      Current:
                      1991 318i
                      2011 328i
                      Past:
                      2002 325i
                      2007 335i tuned
                      • IronFreak
                        • Dec 2012
                        • 3702
                        All the information that I found said the 318 only had the 45mm strut tubes in 84-85 year models.
                        • mr ilia
                          • May 2011
                          • 582
                          My late 318i from 1991 had 51mm struts.
