Standards for refreshing suspension
  • z6ne
    • Dec 2012
    • 758
    If one were to replace many of the main OEM suspension wear parts, what would he be replacing, to get a factory smooth ride?
    -Control arms
    -Control arm bushings
    -Tie rods inner/outer
    -sway bar end links
    -sway bar bushings
    -springs
    -shocks
    What am I missing?
    Also, as far as the rear suspension goes, will I be okay with just doing shocks/springs?
  • agent
    Vice Grand Pubaa
    • 7960
    Originally posted by z6ne
    What am I missing?
    Subframe bushings, diff bushing and RTABs.
    If you're after a "factory smooth ride" you also might want to look at replacing your CSB and giubo.
    Originally posted by kronus
    • LJ851
      • 7919
      -Control arms
      -sway bar end links
      -sway bar bushings
      -springs
      -shocks
      What am I missing?
      EDIT: Slow typing version:
      Plus-
      Strut mounts/bearings
      rear trailing arm bushes
      rear subframe bushes
      diff mount bush
      rear shock mounts
      This assumes your wheel bearings are good
      Lorin
      The M30 is God's engine.
      • agent
        Vice Grand Pubaa
        • 7960
        rear shock mounts
        Hopefully no one is replacing their shocks/struts without these being part of the job...
        • LJ851
          • 7919
          It's the internet, i don't even assume everyone is human here.
          Lorin
          • z6ne
            • Dec 2012
            • 758
            wisdom.
            thanks fellas. Starting to make a list and get prices together.
            • SmokeE30
              • 1730
              You can just replace the ball joints in the control arms instead of the whole thing, and use m3 control arm bushings.
              Shawn @ Bimmerbuddies
              Bimmerbuddies LLC
              717-388-1256
              2971a Roundtop Rd, Middletown PA 17057
              bimmerbuddiesllc@gmail.com
              • z6ne
                • Dec 2012
                • 758
                at a machine shop I assume? How much does this cost?
                • mr ilia
                  • May 2011
                  • 582
                  Where I live, major city, it does not worth the hustle, unless you have a connection of some sort.
                  • z6ne
                    • Dec 2012
                    • 758
                    what?
                    you mean it's cheaper to just buy a whole new arm?
                    • efficient
                      • Feb 2012
                      • 3312
                      cost 66 dollars new for a new a arm on bma.
                      • SmokeE30
                        • 1730
                        what?
                        An OEM arm will cost like 100$ where as some mooge ball joints will run you around 30. Just need a friend with a shop to press them in for you, so add the cost of a 6 pack to that.
                        Bimmerbuddies LLC
                        717-388-1256
                        • Earendil
                          • 1662
                          Plus-
                          diff mount bush
                          rear shock mounts
                          Oh note though, if you're strapped for time or money, and your car has under 200K, you're probably fine to leave the Subframe bushings alone for now. Same goes for the rear diff, unless there is obvious cracking in the rubber. Both of those are in the little benefit for pita work category of parts.
                          Everything else mentioned should be done at the same time as the shocks, as they are highly related pieces, are easy to do at the same time, and provide good benefit.
                          1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
                          2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
                          I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
                          • Wh33lhop
                            • 11705
                            That depends entirely on what shape they're in. They are likely okay but if they are shot it can cause all sorts of fun issues.
                            paint sucks
                            • Earendil
                              • 1662
                              True. My suggestion was only to leave those out if something needed to be left out. Failed rear shock mounts can cause interesting problems too ;)
