Post Z3-Rack Install Problems ::: FIXED!
  • JinormusJ
    • 6887
    I would go Z3
    Z4 rack swap is much more involved; I know Wanganstyle here has done it, but for a daily driver, it is a little excessive. With it being only marginally better than the Z3 rack; for the price and difficulty of the swap (not to mention rarity of the rack) you'd be more happy going Z3 and keeping power steering.
    However, wouldn't hesitate to put a Z4MC rack in a power-deleted track car
    • Wanganstyle
      • 2828
      If you have not even completed a single rack swap successfully then perhaps hold off on the comments.......
      Z4 rack is easy as hell to install and they are more common/newer parts. Z3's are old cars compared to z4 and the market cost of a good z3 rack is MORE than the z4 units.
      Z4 m cars have hydrolic powered steering- only the non-m cars have electric assist in the column.
      Why would you install a power rack just to delete the power?????? Not very logical when there is a newer non powered option avail.
      E46 m3 rack is a good option if more angle is desired and power also.
      Sent from my GT-N7100 using Tapatalk 2
      • JinormusJ
        • 6887
        UPDATE
        So I finally got back from my trip and was able to tackle the rest of this beast. Upon getting my car on jacks I noticed a few things:
        1. Alignment and Auto-Centering
        Yes, it came as to no surprise, my alignment was VERY toe-in /-----\. What I noticed before of just one wheel being off ended up being both wheels off with one way worse than the other. After some 20+ hours of researching steering geometry, castor, toe, and self-leveling; I've learned these key things.
        Toe-in causes the wheels to be in a perpetual gridlock for grip and causes the wheels not to be able to self level, as the wheel opposite the turn (left turn/right wheel or right turn/left wheel) will be continually applying force into a steer. This in turn causes "memory-steer" which is often confused with bump-steer. Memory steer is the aspect that, if you steer to one side, the wheels will steer themselves back to that side because the opposite wheel will lock into more grip and continue the steer, even after the steering wheel is let go (and presumably, in a balanced system, will auto-level). Ultimately, this causes the car not to auto-level while traveling forward.
        Toe-out, \-----/ on the other hand, will place the wheels in a position to where the castor will cause the wheels to be in a perpetual state of correction as both wheels are struggling to steer inward because of the nature of forward travel vs. grip of the wheel, leading to more stability, especially at higher speeds. After I aligned the wheels to correct specs as stated in the e30 Bentley manual: 1/32" toe-out (or close enough to that), my auto-correction worked perfectly fine.
        I also noted that when I was toe-in, auto-leveling worked while I was traveling reverse, but now it work vice-versa (toe-out; auto-leveling while going forward).
        2. Binding Knuckle. Bad.
        I noticed the u-joint closest to the firewall (the top one; connected to the steering column spline, not the rack spline) was binging on itself from the increased angle of the rack; I ended up grinding the squared-off joints with a dremel to round them out, and a little inside the "U" and it freed up enough clearance. Applied some WD-40 afterward for safe measure and I'm free to enjoy my rack.
        3. Bump-steer
        After the barnyard string alignment and knuckle-binding issues were fixed, I took it out for a test drive and noticed NO BUMPSTEER WHATSOEVER with the spacer on top of the rack. It was better than even my stock e30 rack which had loads of bump steer. I made sure to drive over plenty of speed bumps and took an uneven back-road at higher speeds (60-70MPH): no drama to report.
        As stated before, my "bump-steer" was actually memory-steer caused by my toe-in condition, and was confused as bump-steer. I also used the e36 tie-rods (which I highly recommend) because they are beefier, and have better tie-rod joints; these are probably the cause of my decreased bump -steer as my e30 rods were shot
        4. Power steering stuttering.
        I still have slight stuttering from my power-steering going lock-to-lock; not a full "OMG, it feels like power steering is gone" kind of stuttering, but just slight... Difficulty if that makes sense. As I had my car on jacks, I was spinning the wheel lock-to-lock and noticed my air bubbles coming out, so I put my money on air in my system; either it will most likely bleed itself out due to the nature of how BMW designed their power-steering system, or I just have to do a flush. No big deal as it hardly effects driving
        TL-DR
        My problems were:
        1. Alignment was toe-in causing auto-centering not to work; aligning my wheels properly to slightly toe-out (1/32" toe-put) fixed my centering issue
        2. Knuckle was binding; grinded down u-joint with dremel; no more binding.
        3. No bumpsteer at stock height with spacers underneath rack. Stability better than even my e30 rack
        4. Still have some air in system
        • iwantspeed
          • 3164
          UPDATE
          3. Bump-steer
          TL-DR
          My problems were:
          same mistake on the website
          https://www.r3vlimited.com/board/showthread.php?t=298272&t=298272
          https://www.diyauto.com/manufacturers/bmw/generations/3-series-1/diys/post-z3-rack-install-problems-by-jinormusj
          im trying to figure out if i get less bump steer with the spacers below the rack..
          i believe i will since my car is lowered.
          at ride height i dont want the tie rods pointing up from the steering rack
          and your inbox is full
          Project
          Parts for Sale
          Feedback
          YouTube Channel
          • AndrewBird
            The Mad Scientist
            • 11892
            Bump steer is caused from the tie rod and control arm having different pivot locations. The arcs they travel through have different radii and locations, so the change in distance relative to the centerline of the car changes at different rates.
            You would want to put the spacers in where it makes the rack sit with the tie rods as flat as possible. The closer to flat they are, the less change in distance they will have compared to if they started out angled up or down.
