Bilstien bump stop removal question ?
  • retvert325
    • Sep 2013
    • 17
    I am installing bil. sports and H&R race springs on my 325i
    and I see people have removed part of the bump stop to keep
    the struts from bottoming out .
    How much of the stop do I remove ?
    Thanks
  • LJ851
    • 7919
    half is typical
    Lorin
    The M30 is God's engine.
      • 37833
      I always do 1/3.
      Grover Beach, California
      BimmerHeads.com
        • 34847
        Remove less to start. You can always cut more. Putting it back.. well..
        • retvert325
          • Sep 2013
          • 17
          I heard through another forum member that on the sports I don't have to remove any of the bump stop because the sport strut is shortened to work with lower springs . If I had the HD's they would need the bump stop partially removed .
          ???? any thoughts on this .
          • LJ851
            • 7919
            ^ The sports have a shorter extended length (less droop) than HD.
            What you are doing by cutting the bump stop is allowing more up travel (compression) before the shock hits the bump stop.
            Lorin
            • retvert325
              • Sep 2013
              • 17
              ok, so I should remove some bump stop just to be safe ?
              • nrubenstein
                • 3148
                1" of bump stop. No more.
                2002 BMW M3 Alpinweiß/Black
                1999 323i GTS2 Alpinweiß
                1995 M3 Dakargelb/Black
                - S50B32/S6S420G/3.91
                1990 325is Brilliantrot/Tan
                1989 M3 Alpinweiß/Black
