RPM based Whine, PS Pump?
  • ArtClassShank
    • Jul 2013
    • 143
    Hey guys,
    I'm trying to track down a whine I have in my 24V E30. It's based on engine rpm, and will whine with RPM even while stopped. It's a pretty loud whine, sounds like straight cut gears when I drive through a parking lot.
    Heres a video, its pretty prevalent in the first 5-10 seconds.
    So far I've
    • Flushed/Replaced PS Fluid
    • Upper and Lower Tensioner Pulleys
    • Replaced Serpentine and A/C belt
    I got rid of a bunch of other noisy motor issues, but the whine persists.
    After all that, I think I've narrowed it down to a PS pump or the alternator. When you rev it up, it definitely sounds like its from the alternator, but I know the PS pump sits under it, so it might be a wash.
    I'm wondering if anyone else has has a whine like this, and what did it end up being?
    I kinda don't want to drop a bunch of cash on both and cover both my bases, especially since PS pumps are pricey. Hoping I can narrow it down to one of them before this weekend, might pull an Alt/PS Pump from a junkyard car.
    Thanks
    1989 Carbon Black 328is
  • wilholl
    • May 2012
    • 518
    my e36 does this exact same thing even after I changed the alternator.
    Several people have asked if I was running a blower.
    I just smile and go with it
    1988 325 non-letter Seta "Bronzit"
    1991 325ic "Laguna Green" (Sold)
    1993 325i "Laguna Green/Silver" (Sold)
    1998 528i "Artic Silver" m-sport(totalled by drunk driver)
    2000 528i Titansilber/gray m-sport
    2000 528i Titansilber/black m-sport(sold)
    2001 525i Anthracite m-sport(sold)
    2013 750i Black/Black m-sport "Beast"
    • pantelones
      • May 2011
      • 533
      Upon driving my e30 for the first time in a few months I realized that the alternator bearing was on it's way out. Not running power steering, and it comes directly from the alternator so it cant be anything else... I know exactly what you mean by sounding like "straight cut gears" hahaha Pull your belt that runs the power steering pump and see if the noise persist. Provided you can do that on m/s5x motor....
      A man chooses, a slave obeys... Would you kindly?
      • Northern
        I like cupcakes & sh!tboxes
        • 5264
        Still have your radiator clutch fan?
        Originally posted by priapism
        Originally posted by shameson
        • AndrewBird
          The Mad Scientist
          • 11898
          A fan/power steering belt that is too tight will whine. I'd try loosening them up a bit.
          • ArtClassShank
            • Jul 2013
            • 143
            Don't think I can. Runs off the drive/serpentine belt.
            Either going to get a new Alt/Rebuild it and see if that fixes it.
            Lights are also flickering, maybe another indication of a failing Alt.
            • pantelones
              • May 2011
              • 533
              In my case no... The radiator was out for a long bit, and I wanted to get the car up to temp quick/was just doing a short drive so I didn't put the fan on.
              My first thought when I was doing the valve adjustment... It really didn't seem too tight, was under tension and taught, but still easily movable. It sounded more like a bad bearing than a belt squeal while tuning the motor over.
              In my case, the alternator seems to function fine, but I didn't check it with any instruments. It just sounds like a bad bearing. Good luck though! It is kind of a tricky problem to diagnose :)
              • ArtClassShank
                • Jul 2013
                • 143
                Heres another thought, anyone know what a bad mechanical tensioner sounds like?
                I did all 2 of my pullies and got rid of some belt noise, but not the whine. Could it be possible the mechanical tensioner itself I have is bad? BMW did switch away from them some time ago.
                • Wh33lhop
                  • 11705
                  One (relatively) easy surefire check: run it without the PS pump and see if it still makes the noise.
                  paint sucks
                  • ArtClassShank
                    • Jul 2013
                    • 143
                    Well it turned out to be my PS pump. Deleted my PS today and my supercharger is gone.
