PS delete/Steering rack advice
  • Zreberlcoe
    • 1555
    So if I didn't want to deal with my insanely leaky rack, would a Power steering delete be a good cheap option? Or would it be an awful idea with there never being fluid in the rack... I'm in a pickle here, E30 stock racks are wayyyy to expensive for the same damn thing. Doing a rack swap in an airbag car means I have to notch the firewall and or some other voodoo that I am completely inexperienced with. So I have come to the conclusion that if i can do a PS delete when the rack wont hold fluid than I will do it. Or rebuild it but I have yet to see a good writeup on how to do that.
    1991 325i Calypso Coupe
    Like Grandfather, Like Father, Like Son
    BMW
  • vpilarrt
    • Jun 2006
    • 2096
    You don't have to notch the firewall on airbag cars. I did the E36 rack swap in my '91 318is without the notch and it was fine. For all E30's you do have to do the steering coupler mod but its not very difficult.
    • Zreberlcoe
      • 1555
      You don't??? I have only seen such. Or spacing it.
      I know the steering knuckle is a must and that doesn't scare me not does the piping.
      BMW
      • cgk_iii
        • Dec 2012
        • 616
        I just did this swap in my car and it did need some modifications to the firewall.. Without the modification the column binds against the firewall.
        • Zreberlcoe
          • 1555
          Is there a way to space the rack from the subframe?
          BMW
          • mr.vang
            • 4371
            Pulled the rack out and do a full reseal. All you need is a long thin nose pliers.
            • cgk_iii
              • Dec 2012
              • 616
              i wasnt able to fit a spacer.
              i didnt even need to modify the knuckle, just bought a aftermarket steering coupler from IE motorsport.
              • AndrewBird
                The Mad Scientist
                • 11897
                When using a power rack without power, you need to fill the rack with fluid before capping it off. So a leaky rack will still leak.
                • Zreberlcoe
                  • 1555
                  See some say they have had success without the firewall being modified and some say they didn't have to. The guy who did spacers had a 318, so would the larger motor/oil pan have effect on not letting the spacers fit?
                  BMW
                  • cgk_iii
                    • Dec 2012
                    • 616
                    no idea..
                    • dustyperez
                      • Feb 2012
                      • 390
                      I bought a ps delete block from condor. dont miss it and dont even notice unless you are completely stopped trying to turn the wheel. but if you move even a little its easy again.
                      • mulletman
                        • May 2012
                        • 801
                        You actually don't need to do this.
                        A steering rack is a hydraulic system. If you're removing the hydraulic assist, there's no longer any need for hydraulic fluid in the system. Lubrication is necessary, but you certainly don't need a full rack of fluid. A bit of gear oil would probably be sufficient.
                        • Jaxx_
                          • Dec 2009
                          • 1880
                          nope.
                          exactly. In fact, the factory rack is internally lubricated and there is no need to add anything. You don't even need to loop the rack as condor's delete plate suggests. Cap it off the banjo bolts with some tubing after you've dumped as much fluid out of the rack by steering lock to lock. I probably have over 10k miles on mine without issues.
                          • Cletonius
                            • 2809
                            I noticed immediately when my belt snapped. It's not bad without PS but I'll be replacing the belt for sure.
                            - Josh
                            1990 325is
                            Need a shift boot?
                            Looking to buy shift boot frames, PM if you have one to sell
                            Here's what happens when you let the internet pick your license plate
                            • BrandonG
                              • 232
                              I got stock rack and condor ps delete block off plate and 10mm tie rod spacers and new tie rod assemblies I love it !
                              DO WORK
