upper strut bearings
  • NC325iC
    • Mar 2004
    • 6565
    hey guys, as some may know im trying to find a clunking noise in my front suspension, i seem to have found half of the problem which was sway links, but there is still more, i think sometime soon im going to take the front strut out and try to tighten the gland nut at the top of the strut to permanently rule it out, i was wondering if it could be the strut bearing?
    also i was wondering if these things go bad easily, if they are prone to going bad i would like to go ahead and replace it but if itll be ok then ill just keep the ones i have.
    edit: and what brand should i get if i replace them, BMA has febi and meyle for really good prices
    Thanks for the help
    Chris
  • e304me
    • Feb 2006
    • 1374
    just tighten it while its on the car....100x times easier and faster
    • NC325iC
      • Mar 2004
      • 6565
      that would be nice, but i cant, its more than hand tight but i cant tell if its good enough how it is
      • e304me
        • Feb 2006
        • 1374
        I just jacked up that one wheel, then lifted up the boot, stuck a pipe wrench on it and turned
        • NC325iC
          • Mar 2004
          • 6565
          i dont wanna get teeth marks on it but i guess ill give it a try
          • NC325iC
            • Mar 2004
            • 6565
            back to this topic though, really want to know if they have a problem with wearing out
            • fretburnr
              • Jan 2005
              • 1496
              strut bearings do wear out over time. i replaced mine when i installed my cupkit struts and springs, and it made a huge difference in steering response (read:feedback and return-to-center) as well as noise. fyi, i still have a clunk but i haven't inspected my endlinks yet... certainly the strut bearings helped some; however you'll need to compress the springs to replace 'em.
              as a sidenote, i've tightened gland nuts while on the car, using a long large screwdriver as a drift and a hammer
              Jay
              • NC325iC
                • Mar 2004
                • 6565
                yeah i know id have to compress the spring, i dont know if ill do it now or not
                what do you mean a drift, more explanaition
                • fretburnr
                  • Jan 2005
                  • 1496
                  the gland nut has 4 or 6 "ears" on it... just move the dust boot out of the way, point the tip of the screwdriver up against one of the ears in a clockwise fashion, and whack the back of the screwdriver (not enough to shatter it)
                  Jay
                  • NC325iC
                    • Mar 2004
                    • 6565
                    mines only got 2 "ears" if by ears you mean little indentations on the top, ill see if i cant find a picture
                    there you go
                    • fretburnr
                      • Jan 2005
                      • 1496
                      ah, mine are different as they came with my Cupkit...
                      same idea though. imagine though instead of having 2 indentations, it has 4 flaps that radiate outward like a propeller.
                      either way you should be able to tighten as necessary
                      Jay
                      • 155///MPH
                        • 473
                        I'm chasing the same problem currently. I'm leaning towards the strut bearings as I cannot find any play with any of the ball joints.
                        DE's are a tease.
                        Build a racecar.
                        • e304me
                          • Feb 2006
                          • 1374
                          My strut bearings have no play side to side, but if I twist them, (not turn them around, pretend you are looking at the bearing from the side and rotating it clockwise and counter clockwise) then there is a tad bit of play. Is this normal or bad? I was planing on getting camber plates in the next several months
                          • Digitalwave
                            is a poseur
                            • 6293
                            there you go
                            I have the same gland nuts. Just jack up the car and use a long flatheaded screwdriver and a hammer to make sure they are super tight. They can be hand tight and still be loose, if you know what I mean.
                            RISING EDGE
                            • rs4pro3
                              • 5808
                              what you need is spaner wrench, then you can get it nice and tight.
                              85 325e 2.7 ITB'd stroker
