Front suspension squeak (VIDEO)
  • serdar255
    • Feb 2013
    • 395
    Hi, i just started to get this suspension squeak today and wanted to know if anyone knew what it was. The car has KYB, H&R oe sport, and delrin CABs.
    Any help at all would be greatly appreciated, it is only coming from the right front. I searched and the answers were vague, i thought with a video i could get better help.
    image (10) by serdar.gurhan, on Flickr
    PM me for custom shift knobs and stickers!
    Originally posted by marshallnoise
    You ain't done working on a car unless you are bleeding.
  • EyExR
    • Jan 2011
    • 959
    Wow - that's loud! I would get under the car and have somebody else push up and down on the car so you can pinpoint it.... Might help to have a stethoscope.
    My 325iX DIY Threads:
    Front Wheel Bearing Replacement
    325iX Rear Subframe Bushings and MUCH more w/pics!
    325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
    • serdar255
      • Feb 2013
      • 395
      Its quiet on the inside, i was surprised at the noise when i pushed on it.
      Im going to take off the wheel tomorrow and inspect what i can.
      • ///digitalme
        • Dec 2009
        • 2088
        I always had the same squeaking on my 318is, everything seemed fine. I found out what it was after I changed my springs. My tophat was rubbing against the strut mount the previous owner didnt install the washer and dust shield that goes in between.
        • serdar255
          • Feb 2013
          • 395
          Its not the sway bars or anything, i think the sound is coming from the ball joints on the control arm. Does this sound possible to you guys?
          • serdar255
            • Feb 2013
            • 395
            It also sounds like more of a creak from under rather that a squeak.
            • ///digitalme
              • Dec 2009
              • 2088
              Check your subframe it could be cracked by the engine mount.
              • serdar255
                • Feb 2013
                • 395
                Subframe is all good :) any opinions on the CAs though, 99% sure that its that.
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  I'd bet it is the delrin CAB. Did you grease them when you put them together? Even if you did, the grease can wear off and you will get squeaking.
                  • serdar255
                    • Feb 2013
                    • 395
                    No grease, but it just started happening. Ive been running them for a few months and its only one side> It also doesnt sound like the noise is coming from there. It sounds like it is where the ball joint pivots in the middle.
