ANY way to get like 1/4-1/2" more drop in the rear?
  • Jand3rson
    • 37587
    I'm on IE3s and Konis right now, and wondering if there's any way (without irreversible modification) to get the rear to sit down like another 1/4-1/2"? With my new tire/wheel setup, I've got like around 1/2" of fender gap, and I'd like to close it up. I'm going to put 15mm drop hats in the front, but I'd like to bring the rear down at bit more if I can, as well. Anyone have any ideas, or a method that's worked?
  • acolella76
    • 2950
    Dead hookers
    -Alex
      • 34847
      remove the upper spring pads
      • Jand3rson
        • 37587
        Any negative effects to this?
          • 34847
          none that I could tell - ran that way for 5+ years. actually, the side of the spring without the pad was in better shape than the other side because dirt and water didn't get trapped in there. the other irony was the side with the pad still on it was starting to rust, and the side with no pad looked new...
          I mean, if you do it and don't like it, you can always put the pad back on.
          • mccor023
            • Jul 2011
            • 683
            What's your wheel/tire set up? Im on IE3/ Koni with both pads and the iE spacer. Late Model.
            I love that people ask stupid questions so I dont have.
              • 34847
              he has an early model, so imagine another 1/2" of fender gap.
              • Jand3rson
                • 37587
                I'll post a good pic when I get home.
                • series88
                  • Nov 2011
                  • 1231
                  take the spring pads out.
                  • ak-
                    • 12422
                    Was going to mention extended rear shock mounts but realized that doesn't make much sense. Your spring length is the problem haha.
                    I think the guys at catuned made indentations in the trailing arms for the springs to be snug in, like an e36, but that obviously required fabbing. Endless amounts of spring pad adjustment if you would ever do it!
                    1991 325iS turbo
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      Any pictures of this?
                      • Jand3rson
                        • 37587
                        I'm not beyond doing this...
                        • LJ851
                          • 7919
                          If i remember correctly it's like a 2 to 1 ratio of ride height to spring length. If you go this route, i would overshoot so you can fine tune with plastic or hard rubber shims.
                          If you still have both spring pads, i would yank them first to see if you can work from there.
                          Lorin
                          The M30 is God's engine.
                          • Wanganstyle
                            • 2828
                            you dont need the spring pads at all.
                            Nor do you need a spring height adjuster
                            just get the right rate/height spring for your car.
                            we have a spring with the proper rate for our car roughly 3" that just hangs out; jumping FIA berms and passing 2 wheels off is no problem.
                            not even a cable hanger is there. Its so short that when lowering the car one has to make sure it is aligned; but it works well. 15x9 or 17x7 in the back.
                            normal off the shelf billstein shock.
                            • Jand3rson
                              • 37587
                              I'm very captivated by this trailing arm mod, sounds relatively simple. Anyone have more info and/or pics?
