Hello, im going to be replasing the rear axle shaft on my 89 325i and im not so sure what tools i would need tp do the job. Any help will be welcome.
axle shaft question
Tags: None
You'll need a Bentley manual.
- A 30mm? socket for the axle nuts
- A 8mm? allen for the axle flange bolts
- axle puller/pusher (sometimes they get stuck)
- wheel bearings + backing plates (bearings sometimes break when removing the axles)
- wheel bearing press tool
Edit: and a Bentley manual- Josh
1990 325is
Need a shift boot?
Looking to buy shift boot frames, PM if you have one to sell
Here's what happens when you let the internet pick your license plate -
Thanks Oliver :D
I reused axle nuts but obviously replaced the lockplates with new. IMO there's no compelling reason for new nuts unless the old ones are mangled.- Josh
1990 325is
Need a shift boot?
Here's what happens when you let the internet pick your license plateComment
On the axle pusher/puller, if they get stuck, they are REALLY stuck. I tried to knock mine out with a sledge, gave up and bought a 3 hook puller (similar to this one). I then had to use a 3 foot breaker bar on the puller to turn it because it became so tight. Shortly after it gave I had news crews showing up to report on earthquake activity.
Hit it with as much PBblaster as possible, and start that days in advance.-------------------------------------------------
1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!Comment
If his car has spent all it's life in California, it should come out pretty easily. My M3 is a California car, with 210,000 miles on the original shafts, and I changed them this summer. Two swings on a 3 lb sledge and the both popped out.Originally posted by codyep3I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
2002 325xit Sil/blk. SOLD
2010 F650gs twin
2016 M235i cabby. Mineral grey/Red leatherComment
Mine was a NW car its entire life, though it had closer to 300K on the clock when I popped them out. Whose to say I wasn't the first one to do that though..-------------------------------------------------
