So im working on my 1989 325i and im removing the axle shaft but im having a hard time trying to remove the whee hub nut. Does anyone have any suggestions on how i could do it ?could i do it with a impact driver?
wheel hub nut remwval question
Tags: None
Did you remove the lock plate first? A large breaker bar is the best way, but a decent impact gun will work as well. A breaker bar with the car on the ground is easy though. -
I use a heavy duty breaker bar and the handle from my floor jack as a cheater. Only had that fail once, when I was afraid the 1/2" breaker bar was going to break. Switched to the 3/4" breaker bar and spun that sucker off.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
+1 on this method but be sure the handle is no higher than 10 or 2 andnthat you push down or you risk levering your car off the jack stands, with less than ideal resultsSeat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Alice the Time Capsule
87 Zinno Cabrio barn find 98k and still smells like a barn. Build thread http://www.r3vlimited.com/board/show...20#post3455220Comment
