So to start off, ever since ive had this car which is over a year ago ive had a bumping or knocking sound in the rear passanger side. Ive replaced my axle shaft cause i thought that was the problem but it continues. The sound only happens when there are small bumps or the road is uneven. I have no idea what could be causing it. Please help
rear noise problem.
Tags: None
Have you checked your shock mounts? -
Can you replicate it by bouncing the rear when it's parked?Comment
E Brake working correctly?
There's not much else to rattle back there than what has been suggested.
I don't see the subframe or trailing arms rattling unless the bushings are totally shot or gone....or loose?
Check the 4 bolts on the top of the diff and the hanger.Comment
Yeah the ebrake is working fine. Oh i see, well how would i go checking the trailing arm and subframe busjings ? Oh ok, ill check them out.Comment
If it's all original, all the bushings need to be replaced.
Sent from my SCH-I545 using Tapatalk 2Comment
I think they are all original cause ive only had it for over a year. So pretty much all the rear bushing should be replaced.Comment
So i just found out that when i put the car in gear the sound comes out. So im not so sure what it can really be.Comment
