What size are my struts?
  • joshw02
    • Jan 2006
    • 637
    Thinking about going coilovers, and trying to figure out what size my struts are on my 87' 325is. I'm guessing 51mm? Can anyone verify? Thanks..
  • Mr. Tasty
    • Jul 2011
    • 3421
    measure circumference of housings with string. Then divide by 3.14
    Only you can verify, although usually the only 45mm housings were from 83-86 models.
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
    • Holland
      • Nov 2008
      • 7212
      You have two options. 45mm and 51mm. 45 only came on 85 and earlier 318's and some 325's. 51mm was the standard after.
      Originally posted by DEV0 E30
      • Madhatter
        • Oct 2004
        • 966
        ^^ 45mm also came on 320i's, right through series II cars.
        Just a little project im working on
        - http://www.lse30.com -
        • Ray Smoodiver
          • Jun 2004
          • 8809
          It's unlikely to find a 320i in the US AND A though ;)
          As mentioned OP, get the string out, or the verniers.
          • Madhatter
            • Oct 2004
            • 966
            Aren't the only people looking at these forums for reference though :). You'll also find some variations 318is too, well, you do down here. Bit of hit and miss as to what diff and suspension you find in them.
            • Ray Smoodiver
              • Jun 2004
              • 8809
              Oi! I'm downunder too ;)
              I've had a 320i with 45mm struts, my brother had one with 51mm so who knows!
              Only way to is to measure yourself, this things are getting on nearly 30 years now, could have had almost anything done to them by previous owners.
              • atmobenzin
                • 151
                Your brothers car came with ABS perhaps?
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  I have both sizes in my e30 "collection" and the 51mm housings are threaded on the inside so the gland nut has male threads and the 45mm is threaded on the outside so the nut is female.
                  Alice the Time Capsule
