Question regarding testing used Bilsteins before installation
  • CubbyChowder
    • Mar 2012
    • 1487
    I just have a quick question. I am parting out a 325is with Bilstein Sports front and back, and I am planning on selling them as a set, but want to make sure 100% that they are good to go before I sell them. The rears are almost brand new so I know they're good, but the fronts are kind of a different story.
    For the fronts, they are two different part #'s, one is the F4-P36-0335-H1 and the other is the F4-P36-0335-H0, which after some research I found out they are essentially the exact same strut with the same valving, rebound, etc.
    When I compress them, one seems to compress slightly easier and rebounds quicker, the other is a tiny bit harder to compress and rebounds slower, but they both compress/rebound smoothly and consistently. Should I consider these ready to go? I don't want to sell someone a "good, usable shock", when really it's not. Honest answers would be appreciated!
    --Roundie Revival 2.0 - 1973 BMW 2002 Build Thread--
    --Golden Boy E30 Build Thread-- (sold)
  • AndrewBird
    The Mad Scientist
    • 11898
    If there are no visible signs of leakage and they return to full length after being compressed, I would say they are good.
    • CubbyChowder
      • Mar 2012
      • 1487
      So I removed the inserts from the housings today and got to inspect them more. With the collar nut removed, there is a small amount of grease on the shaft during rebound. And one shock is actually significantly easier to compress and it sounds like there is an air leak coming from the bottom silver cap where the bump stop is. What do you think?
      • CubbyChowder
        • Mar 2012
        • 1487
        bump
        • acolella76
          • 2950
          Sounds like one is leaking. If you compress it quickly is there any clunking? Can you feel anything when it changes directions?
          -Alex
          • ForcedFirebird
            • Feb 2007
            • 8300
            You have one HD and one Sport for the front dampers.
            john@m20guru.com
            Links:
            • CubbyChowder
              • Mar 2012
              • 1487
              That's what I thought too. No clunking, it's all smooth. One is just way easier to push in
              Are you sure? Every source of info that I am finding is telling me that they are valved the same and are essentially the same exact shock. Come to think of it, I remember reading that HD's and sports are actually valved that same, so I guess what you're saying could make sense.
              • ForcedFirebird
                • Feb 2007
                • 8300
                Yes, 100% sure. Ordered and installed countless NIB Bilstein shocks/dampers at the shop.
                john@m20guru.com
                Links:
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Isn't the only difference between HDs and sports is that the shaft on sports is shorter?
                  • acolella76
                    • 2950
                    The Sport has a shorter extended length than the HD to accommodate shorter springs. Valving between the HDs and Sports is the same.
                    -Alex
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      That's what I thought. Shorter shaft means shorter extended length, given the same body length.
