GC coilover kit install, do i really need to remove the stock spring perch?
  • Cletonius
    • 2809
    Originally posted by ebox86
    Can you elaborate on this a little bit? I like the way your car sits. Have you cut your tubes to get it that height?
    Originally posted by Cletonius
    I sectioned one inch from the housing.
    I bought my kit all together and when I did, GC needed to know if I was going to section the fronts so they could give me the appropriate length rear springs.
    I'm sitting just about the tallest it will go. I had it aligned and setup on scales at the speed shop down the block, they basically just leveled it out for me after I did the install.
    I guess I'm just confused on what i need to do, i am certain now that the stock spring perches are fine, its more of a convenience issue with getting to the adjuster, but what is the benefit gained by cutting or shortening the strut tubes?
    It depends on what you're doing with the car and the length of your springs.
    If you section an inch from the front housings it will make the front of your car an inch shorter even if you throw stock springs on there. You'll have to get new inserts though since yours are full length.
    You may want to try calling ground control, they will be able to help you get it dialed in the way you want it and they'll be able to tell you if the parts your putting together will work well. (Since everything looked to be all GC stuff)
    - Josh
    1990 325is
    Need a shift boot?
    Looking to buy shift boot frames, PM if you have one to sell
    Here's what happens when you let the internet pick your license plate
    • ebox86
      • Sep 2012
      • 528
      thanks, i will probably need to end up calling GC and explain to them what i'm after. The kit is used and so i got no documentation from the guy i bought it off of. Just new strut inserts from koni, and i freshened up the housing.
      The car is going to be my DD and i plan on lowering it modestly, but i like having the ability to lower if even if its not that much. I wanted to start at stock ride height to see how that felt and then compare that to what lowering it .5", 1", 1.5" etc etc.
      I shall play around with it, give them a call and post my results.
      '99 e46 323i - wrecked
      '87 e30 325iS - sold
      '91 e30 325i - sold
      '89 e30 M3 - fun car
      '09 e91 328i - sold
      '97 impreza - rally car - flipped
      '08 impreza - new rally car
      '01 996 tt - more fun car
      '82 Ford f350 - work truck
      • IronFreak
        • Dec 2012
        • 3702
        what spring rates are you using?
        Instagram @rebellionforge
        • ebox86
          • Sep 2012
          • 528
          350 front
          500 rear
          '91 e30 325i - sold
          '09 e91 328i - sold
          • IronFreak
            • Dec 2012
            • 3702
            That will probably ride much like a fresh stock set of springs.......Guessing of course as I wasn't ever in a brand new e30.......
            • Mr. Tasty
              • Jul 2011
              • 3421
              350 front
              500 rear
              perfect for DD, I have those rates on my e30
              2014 Alpine White 335i MSport
              (Daily Driver)
              Full Mperformance Aero
              KW V2 Coilovers
              VRSF Catless Downpipes
              • Mr. Tasty
                • Jul 2011
                • 3421
                stock rates are lik F130#/R170# lol
                (Daily Driver)
                KW V2 Coilovers
                • IronFreak
                  • Dec 2012
                  • 3702
                  how is the rear 170? for real? wow.........my car is 550/750 so what do I know haha
                  • ebox86
                    • Sep 2012
                    • 528
                    If only..
                    I know! This much I've heard and I'm very excited to try it out.
                    '91 e30 325i - sold
                    '09 e91 328i - sold
                    • Cletonius
                      • 2809
                      350 front
                      500 rear
                      That's pretty soft. I wanted to run rates like that and GC told me I'd crack an oil pan. Ended up going with 440/650
                      Edit: rides firm but not jarring. I've got 80A bushings out back and rubber m3 offset cabs up front
                      - Josh
                      1990 325is
                      Need a shift boot?
                      • ebox86
                        • Sep 2012
                        • 528
                        Interesting, im not worried about the pan or cracking/scraping but i think if you went real low with this rate you'd run into problems but im not planning on that.
                        Im thinking its going to be a firm ride tho, especially when i bolt the Treehouse Racing CABs. Excited to see how those turn out (funny pun is funny :))
                        '91 e30 325i - sold
                        '09 e91 328i - sold
                        • Cletonius
                          • 2809
                          What benefit do the treehouse cabs provide?
                          - Josh
                          1990 325is
                          Need a shift boot?
                          • Mr. Tasty
                            • Jul 2011
                            • 3421
                            increased caster, saves space for swaps with exhausts. Plus they are "solid"
                            (Daily Driver)
                            KW V2 Coilovers
                            • Cletonius
                              • 2809
                              I can see the space saving. they're the same geometry as the m3 cabs right?
                              - Josh
                              1990 325is
                              Need a shift boot?
                              • IronFreak
                                • Dec 2012
                                • 3702
                                Correct^^^
                                And if you want to save a few bucks (not much) Bimmerworld makes them too, and you can actually replace the delrin bushing in it if it wears out. I bought them, think they were like $160.
