I've read confilciting reports on deleting PS with a leaking rack. Some say the rack HAS to be leak free while others say they are internally lubricated.
If my rack is leaking and I want to run without PS, can I do so with a block off plate from Condor with no ill effects? At the moment I don't have the time to install a leak free or refurbished rack so I just cut the belt.
Also, for those that have installed a Condor block off plate, did you notice a difference if you tried a PS delete wihtout the plate and then with?
