Has anybody used Dodge end-links?
  • eLKuRLy
    • Oct 2007
    • 360
    Wondering what other "upgrade" options we have for non-M FRONT swaybar end-links WithOut going to adjustables?
    From pictures, the Dodge Stratus ones look shorter...
    • 34839
    An upgrade would be mounting it to the strut instead of the control arm.
    • joncrz
      • Jul 2013
      • 364
      dont flame me for asking but... why is that?
      My don't quote me list:
      I could be wrong, but I don't think it's a smog test type of thing. IIRC think it's against CA law to *sell* a dual outlet muffler as a replacement for a car that came from the factory with a single. But don't quote me on that.
      • AndrewBird
        The Mad Scientist
        • 11898
        Better geometry. In an ideal situation, the sway bar needs to sit level when the car is sitting on the ground. Because the mount is on the control arm, there is very little distance between the control arm and the sway bar, making room for linkage non-existent. This gets worse as you lower the car more and more. By putting the mount above the sway bar on the strut tube, you have a lot more room to work with and can make the sway bar links whatever length you need to.
          • 34839
          actually it's because the swaybar has more leverage over the strut than it does when you mount it to the arm. so a smaller bar is effectively stiffer.
          • AndrewBird
            The Mad Scientist
            • 11898
            I guess it would, wouldn't it? Further out on the arm means less leverage.
            Stiffer does not always equal better though. Stiffening only the front could result in unwanted understeer. There are way to many variables though to predict that based off of only mounting location.
            • eLKuRLy
              • Oct 2007
              • 360
              Forgot to add on 1st post an "upgrade" that did not involved adding sway link to strut; like them M3
              • F34R
                sLaughter
                • 12376
                1+
                Here is my conversion:
                Instagram: @BWeissLeather
                Current cars:
                ~ '87 325 M30B35 swap
                ~ '87 535
                ~ 01 540 Msport 6spd
                ~ '06 X5 4.8is
                  • 34839
                  why do you think it's an upgrade? it's not going to make the swaybar any more effective.
                  being 5mm shorter or whatever that ends up being isn't going to do anything. you can't eliminate pre-load on the swaybar (or add it). That's the point of adjustable links.
                  • eLKuRLy
                    • Oct 2007
                    • 360
                    I don't think it's an upgrade compared to the strut mount one. Asking if people have use other oem (non strut) type which is "better"/ "more durable" than what we have because I have seen people use other coilovers like BC, Megan, etc. and still use same control arm mount. I would love to modify to strut mount but it's a daily and not in the budget. Maybe in the future.
