It suddenly struck me that I hadn't yet spotted the front sway bar on this car. And for good effin reason - there isn't one. No brackets in the control arms, no endlinks, no sway bar, no sway bushings. And the drive side tab on the subframe is broken off. The shop that "fixed" the car back in the 90's must have just pitched it. Wow.
So yeah, not putting off sways anymore.
Just sprung for the garagistic weld on front strut endlink tabs, and rear endlink mount supports. Also the front subframe sway mount ears - which on the driver side won't be reinforcing so much as restoring a mount point that's gone. So then I'll need swaybars, and front/rear endlinks - e30 m3 front endlinks I guess.
Seems like the UUC bars are the favored ones these days, and seem to come with all the stuff needed to install - bushings, endlinks, even reinforcements.
Question is, should I order their e30 m3 kit, or should I be buying their standard e30 front + rear kits and sourcing different front endlinks. I guess the answer depends on whether the e30 m3 sway setup is the same as the standard e30's apart from the front endlinks.
