:arrow:Corrado G60 struts for coil conversion question
  • aaron_tupper
    • Oct 2013
    • 134
    Has anyone here ever used corrado g60 struts for a coil over conversion? Did you have any problems? I hear that the diameter of them are 6mm smaller is this true and what did you do to fit them?
  • Paradox
    • Jul 2010
    • 337
    I have, no problems at all. Make sure you shorten the strut tube enough to keep the insert tight in the cavity otherwise it will knock around during suspension movement
    • campbellj25
      • 181
      Have them in my car right now. No problems at all, I had to shorten the strut housing 2 inches though.
      • ak-
        • 12422
        So is the diameter that much smaller?
        1991 325iS turbo
        • eLKuRLy
          • Oct 2007
          • 360
          Revalved??
          • Northern
            I like cupcakes & sh!tboxes
            • 5258
            Interested in this answer, since they're reported to be smaller and need some sort of spacer/wrap.
            Also, has anyone ever gotten info from Koni on valving to compare g60 to ix?
            Originally posted by priapism
            Originally posted by shameson
            • aaron_tupper
              • Oct 2013
              • 134
              I dont think anyone has
              • BrandonG
                • 232
                What gland but do you guys use ? I'm about to order kyb corrado struts
                DO WORK
                • BrandonG
                  • 232
                  Nvm ordered billy hd ix inserts
                  DO WORK
