E30 M3 struts bolt in to regular E30?
  • burkey001
    • Feb 2011
    • 608
    Hi, stupid question I can't seem to find a definitive answer on.
    I am having some MCS coilovers made and have the option of using E30 M3 struts to give me the option to adjust roll centre, using Massive/VAC spacers, rather than the fixed E30 regular strut.
    Questions are,
    a) All things remaining 'regular E30' in the front suspension do E30 M3 struts bolt in?
    b) Do they change geometry (roll centre aside). i.e. do they push the track out further vis a vis a regular strut or anything like that?
    If not, what else do I need to change?
    I already have a front strut bar that mounts the "M3 way" so that is taken care of
    thank you
    burkey
    88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
    90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
  • golde30
    • 11464
    they change the mounting point for the sway bar to the strut tube.
    But most importantly, if you were to swap stock for stock there would be alot of positive camber when running m3 strut tubes. this however is a non issue if you are running camber plates. Other than that, they bolt straight on.
    IG: @Baye30
    • acolella76
      • 2950
      The brakes and hub are different, not sure if you already knew that or not but it doesn't hurt to mention. The M3 does have an offset control arm bushing for added caster, but I don't think it's necessary in order to use M struts on a non-M. Didn't know about the loss of camber.
      -Alex
      • burkey001
        • Feb 2011
        • 608
        Well that's a kick in the teeth given my SL6R brake setup. Guess it's regular E30 struts for me. Thanks AColella, you've been helpful here. I'm dealing with your boss Jerome through the local distributor here.
        That's all a bit too hard, too invested in the standard E30 architecture, standard it shall continue to be
        thank you
        • LJ851
          • 7919
          Explain.
          Same control arm geometry and mounting positions (offset bush on M3 of course), pretty sure the same inner fenders where the strut top mounts, what causes the camber change?
          Lorin
          The M30 is God's engine.
          • dsm2002
            • 193
            thank you
            Have you got Lee's brakes? You could always use the SL6R set up with the M3 setup but you'd have to get some brake bells made to match, and maybe modify the caliper brackets. Maybe from Lee.
            • golde30
              • 11464
              Originally posted by LJ851
              Explain.
              Don't know the reason, I just know that's how it was on my swap, as well as the 3 other people I talked to when I was doing the swap. It has to be either different tower shape, or different angle on the knuckle.
              IG: @Baye30
              • Northern
                I like cupcakes & sh!tboxes
                • 5282
                thank you
                You should just need a 5-lug rotor hat to fit the m3, and as long as it sets the rotor at the proper depth for where the SL6R sits you should be fine (ie a hat from wherever your kit is from probably works without new caliper adapters)
                Originally posted by priapism
                Originally posted by shameson
