Rear camber question???
  • e30m3ochoa
    • Aug 2012
    • 136
    Hi, so I have a 91 318i and I need some advice on cambering my rear wheels because they hit the fender on the road. I'm in a budget and I need something that will last me enough to get out of school. I'm not looking for anything high end at the moment just as long as it gets rid of the rubbing and last me about a year or so then that's great. So any suggestions will be welcomed.
    Sent from my LG-E970 using Tapatalk
  • Dakotademon7
    • Jan 2014
    • 446
    I would try to help but I'm a bit lost on why your tires are rubbing. Did you put on wider tires ? Where is it rubbing ?
    sigpichttp://www.germanaudiospecialties.com/
    1986 325es :early:
    • e30m3ochoa
      • Aug 2012
      • 136
      Yeah I put wider tires on the rear. I have 16x9 in the rear. Its rubbing on the top of the rear fender.
      • Mr. Tasty
        • Jul 2011
        • 3421
        Only way to make the rear adjustable are with adjustable trailing arm kits. They are about $100 and need to be welded on. What are your wheel/tire speccs? Have you rolled the rear fenders?
        2014 Alpine White 335i MSport
        (Daily Driver)
        Full Mperformance Aero
        KW V2 Coilovers
        VRSF Catless Downpipes
        • e30m3ochoa
          • Aug 2012
          • 136
          Oh really, that's the only way it can be adjusted? Where can I find them? I have esm 002 16x9 offset 15 center bore 57.1
          • Todd Black 88
            • Oct 2007
            • 3449
            Yes, there is no factory adjustment at all for the rear.
            Originally posted by codyep3
            I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
            2001 silver/Blk 325 cabby. SOLD
            2002 325xit Sil/blk. SOLD
            2010 F650gs twin
            • e30m3ochoa
              • Aug 2012
              • 136
              So where can I find the trailing arm kit?
              • Mr. Tasty
                • Jul 2011
                • 3421
                what size tires
                (Daily Driver)
                KW V2 Coilovers
                • Mr. Tasty
                  • Jul 2011
                  • 3421
                  just roll your fenders, you will gain like 0.5 inch of clearance.
                  (Daily Driver)
                  KW V2 Coilovers
                  • e30m3ochoa
                    • Aug 2012
                    • 136
                    what size tires
                    They are 225/45 on the rear. Even rolling the fenders isn't enough.
                      If rolling the fenders isn't sufficient, the choices then are weld in camber toe kits, wheels with different offsets, or more narrow tires. The first option will result in more rapid tire wear from the increased camber necessary for the tires to clear the fenders. The second and third options will certainly work without other adverse effects.
                      • Mr. Tasty
                        • Jul 2011
                        • 3421
                        what are your rear spring rates?
                        (Daily Driver)
                        KW V2 Coilovers
                        • D J
                          • Apr 2013
                          • 105
                          Get smaller tires. I run 16×9 -3 in the rear on a 205 40 a nice roll and I don't rub at all no adjusters in the rear
                          • e30m3ochoa
                            • Aug 2012
                            • 136
                            Not really sure the rate of my springs cause I haven't don't anything to the rear since I got the car about a few weeks ago. I might put the sport h&r springs from my other along with sport bilstein shocks.
                            • e30m3ochoa
                              • Aug 2012
                              • 136
                              Oh really, so the tire size makes a difference on that? I had no idea it would prevent from rubbing. So you're pretty much running the same setup as me then.
