Lowering question
    • 34844
    they'll probably be OK for street use.
    • Vivek
      attention whore/retard/bitch
      • 6167
      Originally posted by RedReplicant
      My budget setup is the Ground Control coilover conversion kit ($447 shipped), 98 Camaro Z28 KYB Gas-A-Just struts out back ($73 shipped) with 2x McMaster Carr sleeve bearings ($14 shipped), and MR2 KYB AGX struts - pn KYB 765016 ($170 shipped) with the strut shaft milled down to fit the stock front suspension bushing and a spacer inside the strut tube.
      Cut off the stock front spring perch, lower both adjusters all the way front/rear and it's somewhat low - front sits an inch or less above a 14" tire and the rear tire is tucked an inch or so. Get a race camber plate setup up front and you can lop off another inch. You can lose another inch in the rear by removing the coil adjuster... then you can lose another 2" up front by sectioning the housing.
      It DOES NOT get cheaper than this. It will handle well. I went 440lb/650lb springs. $704 for a legit setup is hard to beat in E30 land. I'll post pics of my car tomorrow.
      Originally posted by LittleEcker
      So okay if I get some $400> coilovers just for daily driving (not track) until I can afford something nice, would that be the end of the world? Is there any potential for them just to break on the road or is that really just a track issue?
      $400 coils like joms will work, but you'll be happier with what the guy I quoted posted. Why spend $400 now and save up to spend $700-1000+ in the future? Sounds dumb to me. Do it once and save money.
      1992 Mauritiusblau Vert
      2011 Alpinweiss 335is coupe
      2002 540i/6 Black/Black
      2003 GSX-R 750 (RIP)
      • Cabriolet
        • 9620
        cheapest i've seen a lot of people do and i like.
        get used HR race/IE3 springs
        get use konis or billie sports
        whole thing should run you ~$500
        also bavauto springs are absolute crap
        Much wow
        I hate 4 doors
        • ThatOneEuroE30
          • Dec 2013
          • 8626
          You'll be just fine with joms. Just don't drive like an idiot and dont completely dump them.
          1991 318i 4dr slick top
          Mtech 2 turbo restoration
