manuel rack
  • 318driver
    • 1714
    manuel rack
    ok, so my euro 318i has a manual rack and i plan on putting an m20 in it. I have a donor car and could probably do the power rack. If i did that id like to do power rack sans the power. Witht he manual rack i find it very difficult to drive at low speeds and autoxing was a hassel, which is what i plan to do alot of. Also the steering finds every groove in the road and pull the car in it. if im not paying carefull attention it seems like it can be dangerous.
    noww i here alot of people that like the manual rack, my question is why? whats so great about it? another questions is, how easy is it to put the power rack into my e30 while having the motor out?
    thanks,
    andrew.
    90 325is
    IE stage 3s and refeshed m20....
  • BahnE30
    • 1050
    about as easy as taking everything out of the donor car to do with PS, ie pump, ps pump belt, resevoir, lines, fittings, and the rack it self.... pretty much it
    • AndrewBird
      The Mad Scientist
      • 11898
      You get a lot more "feel" out of a manual rack. There is a lot more feed back in the wheel since there is no power assist.
      • PeaveyBassist
        • Sep 2004
        • 3511
        Dont do a power rack without the pump. Even if there is fluid in it.
        Will
        RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
        Welcome e30 (brilliantrot '90 325is) 12/23/06
        DaveCN = Old Man
        My signature picture was taken by ME! Not by anyone else!
        If people keep quoting me in their sig, I'm going to burn this motherfucker down.
        • AndrewBird
          The Mad Scientist
          • 11898
          Will
          I thought is is what most people did? I believe it's Matt who has been doing this for a while now without problems. As long as the rack is lubricated and there are no leaks, I don't see why it would be a problem.
          • PeaveyBassist
            • Sep 2004
            • 3511
            Isnt a power rack without "power" harder to turn than a real manual rack? I dont think it really causes any technical problems. I just really dont see the point on a daily driver no having power steering.
            Will
            DaveCN = Old Man
            • erik325i
              • Jan 2005
              • 3567
              Will
              Yes. It will be even harder to turn than your existing non-power rack.
              -Erik
              • Insanity
                • Jan 2006
                • 135
                Man, you guys must be weaklings. I took the belt off the power steering pump because the pump is toast, and I don't really feel like replacing it. It's not hard to turn at all, unless you're at a completely dead stop, and even then it just takes some effort.
                I'll take manual steering over goofy overboosted power steering (like so many cars have these days) any day.
                • PeaveyBassist
                  • Sep 2004
                  • 3511
                  Because the e30's is soooo overboosted you get almost no feel from it. I must make it harder to turn in a parking lot when I drive every day. Track car I can totally understand the no pwr steering thing, but on a car you drive every day I just dont get why its so neccescary to have so much feel.
                  Will
                  DaveCN = Old Man
                  • Dave
                    E30 RAT
                    • 11675
                    Will
                    The same reason you want Stage IIIs and a Ryan G splitter on your daily, you silly goose.
                    Current Cars
                    2014 M235i
                    2009 R56 Cooper S
                    1998 M3
                    1997 M3
                    • Axxe
                      • Aug 2004
                      • 3355
                      Stg 3's are actually very streetable, with Koni's they are no rougher than the stock setup.
                      Keep it slideways!!
                      • 318driver
                        • 1714
                        i actually do like hte feel of the manual rack on the turn in, but i have to pull the wheel back when exiting the turn, thats myproblem with it. I know others who remove the ps from the ps racks the wheel snaps back when you let go of the wheel mid turn, correct?
                        Wheni let go of hte wheel mid turn, it will turn back a little but i gota pull it over the rest of the way.
                        90 325is
                        • PeaveyBassist
                          • Sep 2004
                          • 3511
                          Actually... I just got my Bilsteins back from being rebuilt. They should be on the car with the Jstocks hopefully by next weekend.
                          Will
                          DaveCN = Old Man
                          • Dave
                            E30 RAT
                            • 11675
                            Will
                            FUH RAZE WILLY!!!!!
                            Current Cars
                            2014 M235i
                            2009 R56 Cooper S
                            1998 M3
                            1997 M3
                            • AdironRider
                              • Dec 2004
                              • 3491
                              Go for the best of both world and swap in a z3 2.7 rack.
                              Back to my roots
