Hi all
So i installed a used e36 m3 rack and an e30 pump in my car. Since installing everything the entire thing leaks, and its pretty frustrating having to keep filling it. The rack itself does not leak, and prior to install it was not leaking. My suspicion is the lines, or the washers. The lines are used and the washers are all old.
My question is, are the e36 m3 rack p/s lines different sizes? Or are the e30 fitting sizes the same?
Also, would if help to get new washers? Or are washers washers, and don't bother with them? Its going down about a half inch in the reservoir per every other day. Pump seems to not be leaking, and rack doesn't seem to be leaking so thats what leads me to be suspicious of the lines or the washers.
thanks!
thanks!
