Wheel hop?
  • JFarhanbod
    • 2151
    Wheel hop?
    Anytime I accelerate from a stop, the rear right wheel starts shaking and you can feel it throughout the entire car. It's fine after that though. The car also seems a bit bouncy when driving slow but that might just be my suspension. Wheels are balanced so it isn't that. I'm thinking rtab, subframe bushing or diff. I don't wanna just start throwing parts at it though. Any ideas on what it can be?
  • JFarhanbod
    • 2151
    A couple things worth mentioning. Car is automatic, diff is open, all suspension/steering parts in the front are new ( minus swaybar stuff)
    Rear has 6" coilover springs(700lbs) with no adjusters. Rear shocks are w124 bilstein sports. No other things were changed back there.
    • IRON-E
      • 16548
      Bald tires have no grip.
      @IRON-E30 aka Edwin:D
      • efficient
        • Feb 2012
        • 3312
        you sure your lugs are tight and not coming loose
        • JFarhanbod
          • 2151
          That's exactly what it feels like but the tires are brand new 595 rsr's. It did it on my bcaps too.
          • JFarhanbod
            • 2151
            Yep they're tightened
            • RedReplicant
              • Oct 2009
              • 270
              My 240SX did this when the subframe bushings were completely destroyed. If you're gonna replace one of the bushings back there you may as well drop the subframe and do the offset subframe bushings, RTABs, and diff bushing all at once.
              91 318is - Gone
              16 VW GTI
              07 Aprilia Tuono
              • Luke Girard
                • Dec 2013
                • 738
                I had the same problem with my e30 and I was told possibly the driveshaft, shocks, bushings, or axles. You should have a shop look at it if you can't figure it out yourself. If you can find the problem props too you! =) hope that helps check those things out!
                Sent from my DeLorean
                • mcr_driver
                  • 4491
                  Get a jack get down there and check the bushings sound like the right side went bye bye. If the subframe stuff is good maybe the wheel bearing? No whirring noise I assume to rule that out?
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    Blown shocks would cause this.
                    • JFarhanbod
                      • 2151
                      Shocks are brand new w124 billy sports
                      Gonna check the bushings in a bit
                      • Gesture
                        • Mar 2014
                        • 18
                        It could be worn out rear shock mounts or improperly installed aftermarket rear shock mounts.
                        FIST CAN BE A VERB.
                        • JFarhanbod
                          • 2151
                          Checked the diff bushing, it's toast. Not sure about the subframe bushings the look like they might be bad too.
                          Rear shock mounts are billet and seemed to be be in good condition
                          • JFarhanbod
                            • 2151
                            My sense of feel sucks haha. Went to JMP turns out it's the csb. Going to do the entire rear end soon anyways though.
                              • 37829
                              Right when I read your post I was going to say CSB!
                              Classic BMW Specialists
                              Grover Beach, CA
                              www.BimmerHeads.com
