Cabrio Suspension upgrade
  • Bmwb
    • Jan 2013
    • 196
    just wanted to see if this setup will still work on my cabrio or not , also considering advice on a quick cheap way until i have money for a bbk setup what would be good i am turboed aswell so im gonna need some better brakes which should of been my main concern
    i ended up getting my bmw 325is back the previous owner put alot of money into the suspension i wanted to know if i will run into any issues due to me swapping it onto a cabrio
    -Dinan Engineering negative camber plates
    -Dinan Engineering anti-roll bar front and rear
    -bmw e30 m3 front control arms
    -e30 m3 offset control arm bushing set
    dinan does not sell these parts anymore after doing research
    -D190-0363 stage 3 is all the paper says i couldn't find out what it was but im pretty sure it was for the rear
    -D170-1050 2002 camber kit
    -d172-0900
    -d172-0902
    -d172-0903
    and a set of adjustable koni shocks
    pretty sure springs are h & r
    Sold Black BMW E30 325IS
    1987 bmw e30 euro part out
    1990 Bmw 325i Cabrio 2.9
    Metric Mechanic 2.9 stroker
    Holset Hx35w CXRacing Manifold
    MegaSquirt ARP HeadStuds
    OEM HG AEM Methanol injection
    20psi
  • Ether-D
    • Sep 2011
    • 2838
    All will work fine. I believe.
    Originally posted by Andy.B
    I was born on 3/25…
    • Bmwb
      • Jan 2013
      • 196
      I looked everywhere I'm on my phone searching can aluminum ball joints be pressed out and replaced I purchased new ball joints from napa which said I am able to when I took them to the mechanic to replace he said he could only rip the guts out but couldn't take the outer part off and replace it
      20psi
      • Ether-D
        • Sep 2011
        • 2838
        I bet on the aluminum control arm ball joint replacement, it's a no go. Not sure, just an educated guess.
        I was born on 3/25…
        • Bmwb
          • Jan 2013
          • 196
          not to sure trying to find out like i said guy at napa said you can sold me 2 inner ball joints
          20psi
          • Ether-D
            • Sep 2011
            • 2838
            You can with the cast iron control arms. I think he's mistaken.
            I was born on 3/25…
