ST Suspension questions e30
  • cWalk3r
    • Jun 2014
    • 178
    I bought an ST lowering kit for my e30 and was putting it in today and ran into a problem.. My car is a 325i vert 1990 and I measured it and it has 51mm struts. So I'm putting them in and I can't get the oem strut insert nut back on. The top of the ST insert is larger than the oem and ST didn't supply another insert nut. If I put the car together without the nut on, the whole thing looks like it would be unsafe. Any know what I can do? Or has used the ST kit? I really need help, thanks
  • IRON-E
    • 16548
    Pictures?
    @IRON-E30 aka Edwin:D
    • cWalk3r
      • Jun 2014
      • 178
      Here are some pictures. As you can see the collar nut doesn't fit over the black ST insert.
      Here's the orange one threading in
      Here's the black on not threading in as the body is to big
      Is there supposed to be a new collar with the kit? It can I simply just not use a collar? Do I have a 51mm strut or would this be considered a 45mm? Since the oem shocks have that groove?
      • Rc 415
        • Jun 2011
        • 723
        I would call st suspension directly. What came with the shocks? Just springs?
        1987 Delphin 325IS
        LS1•TSP 228r• condor speed shop solid subframe, diff, fcab, mounts•Airlift air ride suspension•e36 ps rack•Eibach sways•16" Spal puller•bbk 310mm front & rear•17" BBS RS•
        Build Thread
        1993 alpine 2 325IC
        •Ground control coilovers•16" BBS RS• momo woodgrain
        • cWalk3r
          • Jun 2014
          • 178
          Yeah just springs. I don't really feel like going through the hassle of shipping everything back as I'd loose money so I'm planning to have the strut inserts lathed down a few mm's so the threaded gland but fits over the insert. Might not be the safest but it's the only thing I can think of unless I just weld the insert in or weld a washer on top
          • AndrewBird
            The Mad Scientist
            • 11898
            Turning the struts down is a BAD idea. The metal is very thin (think sheet metal) and there is a good chance they will tear open as you are turning them.
            I'm guessing you have the wrong struts for your strut tubes. Call ST and see what they say.
