E36 M3 inserts in E30 struts?
  • HennaE30
    • Apr 2014
    • 1965
    I have looked everywhere and cannot find an answer to this question, theres a guy on CL selling BNIB Koni Yellow E36 M3 strut inserts and i was going to pick em up for my car if i knew they fit. I cant find what the E36 strut housing diameters are, so im not sure.
    Thanks
    Originally posted by flyboyx
    how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
    Originally posted by Northern
    beer is my new liver cleanse.
    Henna - '84 Hennarot 325e
    Lola - '89 Schwarz 325is - being saved
    Christine - '88 Schwarz 325is - Spec E30 Racecar
    '01 White F150 Lariat 4x4 Supercrew - Daily
    Dad's '05 Interlagosblau M3
  • M-technik-3
    • 18946
    They mount differently. They have a bolt that holds them in place from below. But that being said you might be able to modify them to work.
    • HennaE30
      • Apr 2014
      • 1965
      Would it be possible to just cut the bolt off and use the collar nut to hold the insert in?
      • M-technik-3
        • 18946
        Not sure what the diameter is, honestly it would be cheaper to get Koni inserts for an e30 vs hacking these to install them
        • HennaE30
          • Apr 2014
          • 1965
          E30 Konis are ~$650, these fronts are $225
          • mr2peak
            • 2388
            I'd wait and get the right part. They are going to be valved for the weight and suspension geometry of an E36, you're better off with e30 specific stuff unless you are going to have them revalved for this application.
            Drive it hard. Maintain it well.
            A Topless Memorandum
            • gotaloveRWD
              • Jul 2011
              • 708
              I'm wondering the same
              I'm assuming if the od and the length are the same the only other problem might be the strut rod that goes through the locking collar
              IG- nv_e30
              • gotaloveRWD
                • Jul 2011
                • 708
                What about the people who do the 5 lug conversion, I doubt they get then revalved
                IG- nv_e30
                • M-technik-3
                  • 18946
                  Bav auto which tends to be higher has them for 194 each fronts. You could buy them and then resell them making a bit of profit is an option.
                  • RedReplicant
                    • Oct 2009
                    • 270
                    5 lug conversions like this have greater issues.
                    91 318is - Gone
                    16 VW GTI
                    07 Aprilia Tuono
                    • DER E30
                      • Sep 2013
                      • 2347
                      Buy 'em and see! If they don't look useable resell them...
                      -Christian
