Do i need a spring compressor to remove e30 m3 stock front springs?
  • CMG
    • Apr 2008
    • 736
    Obviously it's better to use a compressor but for e30 m3 is there really that much tension in the front springs to worry about when removing with airgun?
  • glnr13
    • 1334
    people who live on the side of danger just put that strut on some grass, step on the spring, hit the top nut with impact, boom it comes apart.
    • Cabriolet
      • 9620
      auto zone rents them for free. there is about 150lbs of preload on them. you don't need one but that could also be said of one of your eyes as well. just rent one real quick
      Much wow
      I hate 4 doors
      • CMG
        • Apr 2008
        • 736
        I had no idea it was free. Definitely not worth the injury. Thanks
        • eLKuRLy
          • Oct 2007
          • 360
          +1 Most auto parts stores rent tools for free. Obvious you have to pay for tool to "check out/loan" it but get back your money. I did this until just got some cheap Harbor Freights ones for like $10.
          • mr.vang
            • 4371
            Put one of your wheel on top of the spring and have your fat friend sit on it. It is not as bad, everyone is just overrating it. You will need one though if you're installing them back with stock shocks.
            • CMG
              • Apr 2008
              • 736
              I've pulled lots of springs but they're usually lower springs with no tension. Got the compressor, plus the forks for the ball joints. Any tips for removing ball joints with tearing?
              • acolella76
                • 2950
                Thread the nut onto the stud so you don't mushroom the threads and whack it with a hammer. It'll come loose.
                -Alex
                • CMG
                  • Apr 2008
                  • 736
                  Well got everything apart with the exception of one lollipop stuck on the conteol arm. Definitely recommend compressors it would have popped for sure without them. Btw i scored a complete e30 m3 front suspension with aluminum control arms for $450, hell yeah. My plan is to use existingsuspension on car plus this and have complete stock and track suspensions that i can swap out between
                  • Navarone
                    • Jun 2014
                    • 935
                    With a couple good swings with a BFH you can pop ball joints out of the spindle. I had to press the control arm bushings off the control arm and out of the lollipop. I hated those.
                    • CMG
                      • Apr 2008
                      • 736
                      I actually used the fork for the tie rod end but whacked tbe control arm cuz none of the forks were the right size in the first place.
                        • 34839
                        I do it that way all the time. Actually, I'd rather do it that way - there is actually a lot less potential energy to be released than when compressing the spring all the way to remove it.
                        Significantly less, in fact. All that should be compressed with the springs in the strut are basically the dead coils (they just hold the spring in place). You're talking 40-50lbs of force at most. When you compress it 2-3 inches, there could be 600-800lb of force snapping at you if the half-worn out spring compressor you borrowed breaks (or the Chinese one from HF).
                        Not much really happens, nothing goes flying, and it's really quick. win/win.
                        • elbrack
                          • Jul 2013
                          • 176
                          How dangerous are we talking? I've got the impact to do this.
                          • M-technik-3
                            • 18946
                            Ok put it this way, your going to need the tool when it comes time to reassemble them.
                              • 34839
                              who puts stock springs back in these days? Usually the new springs are so much shorter, it goes back together without compressing anything.
