Easy way to replace front springs?
  • Hoffbrohaus
    • Sep 2013
    • 519
    I only want to swap out my springs do I have to take the whole strut assembly out or can I just unbolt the top, swing it out, compress the spring and pull it out? Or do I have to go through this whole procedure on pelican?
    '90 325is
    • 37829
    I think you'd spend more time trying to do it "in the car" than pulling the complete assembly. It really doesn't take that long. I can usually do both sides in an hour at most.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • IRON-E
      • 16548
      I agree in with MR.325
      @IRON-E30 aka Edwin:D
      • Jaxx_
        • Dec 2009
        • 1880
        The longest part is compressing the springs, and probably more hassle doing it on the car rather than on a work bench. Not to mention, you may not even be able to clear the fenders to pull the springs off with spring compressors attached to them.
        • MuddyDuck
          • Nov 2014
          • 8
          Pull the whole assembly. I spent an hour in the ER after gashing my finger trying to do it on the car. Much, much easier once removed. I wish I'd spent that hour removing them from the start.
