You tell me which one's I should get. RSM's
  • Axxe
    • Aug 2004
    • 3355
    Meyle Heavy Duty. Dirt cheap, $12 / side from BMA IIRC.
    Keep it slideways!!
    • Mastrcruse
      • Sep 2005
      • 5340
      Are the Meyle HD's the second to the last product?
      Would I need the strut mount gasket?
      http://www.bmaparts.com/epcvsoapimc....entid=bmaparts
      • Mastrcruse
        • Sep 2005
        • 5340
        Just got in contact with IE and they are out of stock for a week. I have heard if I drive on back RSM's that I can crack the body. Is this true and if so are these the GC one's?
        Also, I see that they have different stem diameters. I am going to get the KW setup so should I just stick to the 10mm?
        • 87Blue325iC
          • Apr 2006
          • 1111
          I'm happy with the IE's - very well made. I put them one as part of an entire suspension upgrade/overhaul, so i really have no way to tell you what difference they specifically made...other than piece of mind that they will probably never fail!
          Aaron
          • Mastrcruse
            • Sep 2005
            • 5340
            So can I drive on bad ones for a week?
            • Mastrcruse
              • Sep 2005
              • 5340
              IE's are ordered
              • Sean
                • 5793
                Werd.
                Those IE mounts look bulletproof! You'd have to total your car to destroy them! lol
                - Sean Hayes
                • Mastrcruse
                  • Sep 2005
                  • 5340
                  Finally recieved my RSM's from IE and they WOW me by how much better they are built compared to stock.
                  One question, Which size washer goes toward the back? There are two sized washers, big and small diameter, and I don't know which one faces which way. I don't really understand why there are two different size washers but I know that it goes...
                  Main piece (mount), CAR, second bracket, small washers, other washers (different sizes??), nuts.
                  Is this the right order? If someone has a pic of IE RSM's from the top please share.
                  Thanks
                  • Mastrcruse
                    • Sep 2005
                    • 5340
                    Just edited above can anyone help me out please?
                    Thanks
                    • 87Blue325iC
                      • Apr 2006
                      • 1111
                      Thanks
                      Don't think it matters which washer goes where - maybe it does on a coupe, because the mounts are in the trunk.
                      The order should be:
                      Main mount
                      Thin paper seal thingy
                      CAR
                      thin metal bracket
                      washers
                      smaller washer to keep nuts from sinking in the bigger washers holes
                      nuts
                      Aaron
                      • Bimmerfanatik
                        • May 2004
                        • 5349
                        Main mount
                        CAR
                        thin metal bracket
                        washers
                        nuts
                        Aaron - hot car, makes me want the kopis even more for my car ;)
                        Got any more pics of your car?
                        PS - I might have to save up and get the IE RSM's as they seem to be a hit!
                        • bwanac
                          • 3354
                          Originally posted by nando
                          I've had the E46 M3 cabby mounts for several years now, they've worked out very well and were cheap too.
                          Dittos.
                          • Mastrcruse
                            • Sep 2005
                            • 5340
                            Main mount
                            CAR
                            thin metal bracket
                            washers
                            nuts
                            Thanks for all the help again. I am going to install right now.
