While i'm in there....
  • ElJimo
    • Jun 2012
    • 166
    Hey R3v,
    Was doing a steering rap swap this past weekend (e46) and while i was down there i noticed the sorry state of....everything else. I figure while I have the car up on stands I might as well do the suspension. I need endlinks, control arms, swaybar mounts (20mm) and CAB's. Does anyone have any reccomended brands/vendors that you would personally source these from? I've been looking through blunt, IE, and pelican and they all seem to have some but not everything. Also am unsure of getting m3 CAB's vs. normal. Any input is appreciated. Thank you.
  • rturbo 930
    • Dec 2005
    • 2619
    Endlinks
    Left Control Arm
    Right Control Arm
    Sway Bar Mounts
    CABs
    M3 CABs give you more caster which is good for stability at higher speeds. It's a common upgrade.
    • ElJimo
      • Jun 2012
      • 166
      Thanks for the links. For the sway bar mounts I actually need the whole thing, not just the bushing. I was looking at this.
      Also, I was thinking of going poly for the CAB, can anyone with experience on the matter tell me if the extra harshness is worth it.
      Bushing Type: 1 -Frnt Lwr Cntrl Arm Bush, Rear, Alum, Offset, St; 1 -Frnt Lwr Cntrl Arm Bush, Rear, Alum, Offset, Ra; 1 -Frnt Lwr Cntrl Arm Bush, Rear, Alum, Center, St; 1 -Frnt Lwr Cntrl Arm Bush, Rear, Alum, Center, Ra; 1 -Frnt Lwr Cntrl Arm Bush, Rear, Eccentric, Stree; 1 -Frnt Lwr Cntrl Arm Bush, Rear, Eccentric, Race; 1 - Front Lower Control Arm Bushing, Rear, Street; 1 - Front Lower Control Arm Bushing, Rear, Race; 1 -Front Lower Control Arm Bushing, Rear, Heritage; 2 - Front Sway Bar Bushing - 18.5mm, Street; 2 - Front Sway Bar Bushing - 18.5mm, Race; 2 - Front Sway Bar Bushing - 18.5mm, Heritage; 2 - Front Sway Bar Bushing - 19mm, Street; 2 - Front Sway Bar Bushing - 19mm, Race; 2 - Front Sway Bar Bushing - 20mm, Street; 2 - Front Sway Bar Bushing - 20mm, Race; 2 - Front Sway Bar Bushing - 21mm; 2 - Front Sway Bar Bushing - 22mm, Street; 2 - Front Sway Bar Bushing - 22mm, Race; 2 - Front Sway Bar Bushing - 24mm; 3 - Sway Bar Link Rod Bushing, Street; 3 - Sway Bar Link Rod Bushing, Race; 4 - Rear Beam Bushing, Street; 4 - Rear Beam Bushing, Race; 5/6 - Rear Trailing Arm Bushing, Street; 5/6 - Rear Trailing Arm Bushing, Race; 5/6 - Rear Trailing Arm Bushing, Adj, Street; 5/6 - Rear Trailing Arm Bushing, Adj, Race; 6 - Rear Sway Bar Bushing - 12mm, Street; 6 - Rear Sway Bar Bushing - 12mm, Race; 6 - Rear Sway Bar Bushing - 13mm, Street; 6 - Rear Sway Bar Bushing - 13mm, Race; 6 - Rear Sway Bar Bushing - 14mm, Street; 6 - Rear Sway Bar Bushing - 14mm, Race; 6 - Rear Sway Bar Bushing - 16mm, Street; 6 - Rear Sway Bar Bushing - 16mm, Race; 6/7 - Rear Sway Bar Bushing - 15.5mm, Street; 6/7 - Rear Sway Bar Bushing - 15.5mm, Race; 6/7 - Rear Sway Bar Bushing - 18mm, Street; 6/7 - Rear Sway Bar Bushing - 18mm, Race; 7 - Rear Diff Mount Bushing, Street; 7 - Rear Diff Mount Bushing, Race; 15 - Rear Sway Bar Link to Arm Bushing, Street; 15 - Rear Sway Bar Link to Arm Bushing, Race; 16 - Rear Sway Bar Link to Sway Bar Bushing, Stree; 16 - Rear Sway Bar Link to Sway Bar Bushing, Race; 30 - Rear Shock Mount - 10mm, Street; 30 - Rear Shock Mount - 10mm, Race; 30 - Rear Shock Mount - 12mm, Street; 30 - Rear Shock Mount - 12mm, Race.
      I've also been considering solid mounted CAB's such as treehouse racing.
      • rturbo 930
        • Dec 2005
        • 2619
        What are you doing with your car? Street, street/track, track only? If it's only street, or street and light track/auto-x use, I would just get OE rubber. OE M3 CABs are stiffer than the regular ones, BTW.
        If you need the sway brackets too, I think I'd just order new OE brackets.
        As for poly bushings... I have poly TAB and subframe bushings. I don't think the ride is too harsh or anything, but I think it would've been easier to just use OE pieces. The TABS were a BITCH to install, and the subframe bushings I didn't get mounted right (although that's probably my fault - still need to look into that).
        I don't have experience with them, but I definitely wouldn't get solid CABs for a street car. The only place I would consider using solid bushings on a street car is the TABs, reason being, the trailing arms are mounted to the subframe, which is isolated from the chassis by the subframe and diff bushings. I might do that when I do my subframe again. I do have some suspension squeaks, BTW, not sure where, but I'd bet it's my TABs. Not very bad though.
