Get real - virtually!
Forget damper travel. The damper's range of movement exceeds the spring's length of compression. In the real world of sedans a lot of theory goes out the window. Polar moment says add weight inside the wheelbase yet a sedan works better with 100# in the far right rear.
Questions: Where does the gain from a lower center of gravity start being offset by the "screwed up" geometry? What is the ideal ride height? What is the ideal amount of body roll?
If body roll is decreased, the suspension changes in cornering are decreased.
A serious chassis tuner that's starting to ask questions like this one should get a suspension software program that allows you to turn the wheels and roll the chassis.
I'm just curious but don't a lot of the responses to this thread imply knowing where the center of gravity is? Has anyone calculated the center of gravity of an E30 from front to rear?
