coilover maxed out on rear
  • e30 power
    • Mar 2006
    • 413
    so my rear coilers are bc racing. and maxed out and not low enough like i want it to be, purges out and all.... so came to the conclusion that i need shorter shocks first, to see if it may drop some more. since the car is resting on bump stops.....
    do you guys know who sells shorter shock body shocks? or anyone have had any experience with this?
    8)8)
  • DER E30
    • Sep 2013
    • 2347
    Why not pull the shocks to see if they are the problem before ordering anything?
    -Christian
    • ak-
      • 12422
      The shock body is already pretty short and you're able to twist them even shorter if you haven't yet. What size spring are you using? That's usually the popular problem.
      1991 325iS turbo
      • e30 power
        • Mar 2006
        • 413
        hmm maybe i will try pulling them off real quick see it drops more....
        and i have them all the way down and everything off the spring. and not sure the size spring can't remember what size they are i guess i should measure them.
        8)8)
