How Do I Get A Wider Stance?
  • rose89
    • Jun 2006
    • 9
    I'd like to upgrade the suspension and improve the handling any way I can while keeping the stock look.
    Is there any way to widen the stance of my car? The tires could probably come out an inch or so and be even with the fender.
    Also, what is the best suspension upgrade? I don't want to lower it and I don't care if the ride is a little stiff. My daily commute is through twisting valley roads and I really don't like slowing down through the corners.
    PLEASE DON'T MOVE THIS THREAD. THE SUSPENSION THREAD DOESN'T GET ENOUGH VISITS.
    1989 325i
  • MikeK
    • Jan 2005
    • 2771
    big ass sways, 20mm spacers, shocks, and lose the fat chick
    Toyota Pickup
    • Erisa_1974
      • Jun 2006
      • 25
      • Dave
        E30 RAT
        • 11675
        Dayton wires with -20 offset and itty bitty white walls.
        Current Cars
        2014 M235i
        2009 R56 Cooper S
        1998 M3
        1997 M3
        • Van Westervelt
          • 9365
          spacers and thicker sway bars is my vote. anything else and you will have to lower it a little. H&R sports lower it only an inch or so I beleive. So its not too bad and its stiffer I gather.
          • AndrewBird
            The Mad Scientist
            • 11898
            E30 M3 springs might be good also. Little bit stiffer with only a slight drop.
            • rose89
              • Jun 2006
              • 9
              Thanks. I pulled the fat chick out. Had to grease her up first.
              Where's the best place to get the parts? I found H&R OE Sport Springs that have the least drop ($268.00), and Sway Bars ($472.75) at pelicanparts.com. Is this a good deal?
              Should I replace the shock absorbers at the same time?
              1989 325i
              • silverfbimmer
                • Feb 2006
                • 309
                Has anyone had any experiences with Intrax sway bars? I saw them on flyingbrick for like 300 for front and rear. I am also going after the same thing rose89 is, though I already lowered my car.
                • Garageaholic
                  Freestyle Fabricator
                  • Dec 2005
                  • 5204
                  I have suspension techniques sway bars. the rear SB is shady, but i got them (22 front/ 19 rear) for about $330 for both....that was on... flyingbrickperformance.com
                  And the springs, you can find HR sports for cheaper.... guaranteed.. try turnermotorsport.com
                  Recent Rebranding!!
                  E30 SM62/S62
                  E30 M60 V8
                  E30 M30 Big 6!
                  Instagram.com/garageaholic
                  Youtube.com/garageaholic
                  • Jbpka06
                    • Feb 2006
                    • 551
                    i just bought H&R sports from www.bimmerworld.com for $237 shipped.
                    • Charlie
                      kid tested, administrator approved
                      • 6686
                      20-25mm spacers and a good fender roller.
                      -Charlie
                      Swing wild, brake later, don't apologize.
                      '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                      FYYFF
                      • IS
                        • Jul 2005
                        • 366
                        I have a set of eibach pro kit and a set of h&r sports (soon). Albeit they lower the car, I'll let them go for $140 shipped (each set)!
                        Also, if you're going to increase your track substantially, get some fender flares. Otherwise, your car will look retarded.
                        87 325IS - Delphin Grey/Cardinal
