Need help..urgent...front end noise.
  • etaclay
    • Jul 2013
    • 105
    So 3 weeks ago I decided it was time to replace all my suspension and front arm control components as they looked to be original. The car is a build date 02/85 325e coupe.
    Here is a list of everything I replaced:
    Front-
    Lemforder Control arms
    Condor Speed Shop offset solid CABS
    Meyle HD sway bar links
    Bilstein sports with H&R super sport springs
    OEM strut mounts
    The car also has an e36 steering rack with e36 tie rods
    Rear-
    Turner motorsports solid shock mounts
    Now, to the issue. I have noticed a noise coming from the front end suspension. It's sort of like a clunk after going over bumps. It happens at various speeds, whether slowly going over speed bumps (~5 mph) to going over rough patches of road. Tonight I noticed that the clunk would happen repeatedly after going over bumps. I never worried about taking my e30 anywhere and now I'm really not wanting to drive it at all.
    Has anyone experienced anything like this? I have double checked and made sure everything was tight and connected properly.
    Any insight would be extremely helpful.
    Thanks r3v.
    325e Schwartz coupe(02/85) OBDII M52B28+ZF320 swapped
  • efficient
    • Feb 2012
    • 3312
    Maybe a loose top hat.
    Loose shock cartridge.
    Loose sway bar end links.
    You made sure you tightened the big nut on the control arm that connects to the sunframe.
    • ST1G
      • Oct 2012
      • 6689
      I would say it's either this, or the nut on the strut isn't tight. It's a bitch to get the nut tight enough because the strut piston spins.
      You can test this by opening the hood, and rapidly and forcefully push up and down on the car on the fender by the strut/top hat. You should be able to clearly hear it, and maybe see that it's loose.
      • etaclay
        • Jul 2013
        • 105
        For sure both control subframe bolts are tight. First place I checked. My original thought was that the shock wasn't tightened in the strut housing so I pulled it apart and re-tightened it. No change.
        • etaclay
          • Jul 2013
          • 105
          I think I've done this test already as I've read something similar, but I'll double check. I used an impact with a thin wall socket to get it on tight.
          • agent
            Vice Grand Pubaa
            • 7960
            Yep. I've had this issue both times I've done work to my front suspension. Both times the nut on top of the strut was loose by about a thread. Run the impact on it for a solid 10-15 seconds. When you think there's no way it could be on any tighter, run it 5 more seconds.
            Originally posted by kronus
            • kickinindian
              • 2327
              also use a rag and some vicegrips on the shaft part of the shock to help in not spin as much, mine did the same thing, and even with an impact it would not do the last little but, just needed a little help keeping it from spinning did the trick
              • AlonzoS
                • Apr 2012
                • 334
                9/10 it's that nut. Had the same issue, just tighten that thing up
                • etaclay
                  • Jul 2013
                  • 105
                  Thanks gentleman. Will do this tomorrow on my off day. I appreciate all the helpful comments. Will report back after its done!
                  • DRTSRFR
                    • May 2008
                    • 1836
                    Double check the washers under the top mount. If one is missing, tightening the nut won't help.
                    Check the link in my sig for a diagram...
                    Suspension tips here...
                    http://www.r3vlimited.com/board/album.php?albumid=757
                    • McGyver
                      • 4607
                      rag/electrical tape on pliers/vice-grips or a strap wrench to hold the strut, then impact on the top nut.
                      • etaclay
                        • Jul 2013
                        • 105
                        I checked the diagram, I recall when taking my suspension off, part n#7(31331110196) and #8(07119931021) were not there. Would this cause it? I ask because I did not have the noise before the suspension swap.
                        • etaclay
                          • Jul 2013
                          • 105
                          Also, on another diagram of the strut assembly on realoem.com there's part #6 called threaded ring with external thread(pn 31321117376). I do not remember taking this part off. Could that also cause the issue? Tried to upload diagram photo however it kept failing. I figure you guys probably know what I'm talking about.
                          • DRTSRFR
                            • May 2008
                            • 1836
                            If 7 and 8 are missing, you will definitely have a clunk. It's quite common for these to be missed when re-assembling.
                            pn 31321117376 is the gland nut which retains the damper(strut) insert.
                            • etaclay
                              • Jul 2013
                              • 105
                              I appreciate your help. I believe part #7 and #8 are causing the issue as well as the missing washer on the top of the struts. I'll be ordering them from bmw tomorrow.
