Rear Spring installation
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    Is there some kind of trick to get the rear springs in? I have the subframe in. I'm NOT taking that out after the crap I had to go thru to replace those bushings.. but the trailing arm is hanging down as low as possible and it looks like I'm still going to need to compress the spring on both sides in order to squeeze it thru the stock rubber spring pads.. Is this true? or is there a trick?
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
  • arsevader
    • May 2005
    • 1025
    Stock springs? or lowered. Lowered should go in no hassle, stock you may have to compress.
    I assume you have dissconnected the shock from the triling arm. Be careful of the CV joints on the half shafts. You don't want to over stress them.
    • Garageaholic
      • Dec 2005
      • 5204
      Yeah, they're HR sports, I forgot about that, they're lower already anyway.... yeah i disconnected the shock already..after realizing that i don't think it should be toooo too hard...
      I have to re-install my half shafts because i replaced my rear bearings.. That will be a bitch. those splines are TOIGHT!!
      Recent Rebranding!!
      E30 SM62/S62
      E30 M60 V8
      E30 M30 Big 6!
      • kencopperwheat
        King of Kegstands
        • 14396
        Take the rubber pads out. If you have the shock and the sway bar disconnected, they should go in without a problem.
        Originally posted by Gruelius
        • netcsk
          • Apr 2004
          • 1609
          I got nasty sounds with no rubber pads in my car. Not to mention it rubbed all of the paint off of the springs and induced rusting.
          • Garageaholic
            • Dec 2005
            • 5204
            nooo i don't intend to take the pads out. I'm using the pads..besides, the rear will be too low anyway w/o pads.. i dont want my ass draggin'
            Recent Rebranding!!
            E30 SM62/S62
            E30 M60 V8
            E30 M30 Big 6!
            • KangamangusDriver
              • Aug 2005
              • 1870
              -Crow Bar
              Thats what I had to do to squeeze my H&R sports in with the sways and shock disconnected.
              • beamR X
                • Apr 2006
                • 145
                There is no trick and they will simply slide in place, but you have to drop the diff. In order to do that you have to drop the muffler.
                Proper procedure is:
                Jack the car.
                Take wheels off.
                Disconect the shocks and sway links.
                Lower the muffler.
                Lower the diff. (you only need to remove the big bolt (19 mm???), drop the diff enough to slide the diff bushing down the bracket, but so it does not come off the bracket)
                Control arms will then have enough drop to simply grab the springs and re and re them.
                I know theis sounds like more work but it really isn't. The muffler and diff drop and re mounting took me about 10-15 additional minutes, but it insures that you are not phucking the CVs...
                (.Y.) R cool.
                Falco rocks!
                • browntown
                  • Jun 2004
                  • 3524
                  Jack the car.
                  Take wheels off.
                  Lower the muffler.
                  A similar procedure is in the Pelican article here: http://www.pelicanparts.com/bmw/tech...ear_Suspen.htm
                  • IS
                    • Jul 2005
                    • 366
                    Yes, the only proper way of removing stock springs is to lower the differential a bit. Using a jack and a block of wood makes this very easy.
                    87 325IS - Delphin Grey/Cardinal
                    • PeaveyBassist
                      • Sep 2004
                      • 3511
                      Or just compress the stock springs.....
                      Will
                      RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                      Welcome e30 (brilliantrot '90 325is) 12/23/06
                      DaveCN = Old Man
                      My signature picture was taken by ME! Not by anyone else!
                      If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                      • Garageaholic
                        • Dec 2005
                        • 5204
                        I compressed the stock springs and they came out. It was actually very easy.
                        Spring compressors are $12 on ebay.
                        Recent Rebranding!!
                        E30 SM62/S62
                        E30 M60 V8
                        E30 M30 Big 6!
                        • PeaveyBassist
                          • Sep 2004
                          • 3511
                          x2
                          Will
                          DaveCN = Old Man
                          • DEV0 E30
                            • Oct 2004
                            • 8892
                            Or $10-20 at a local auto parts store.
                            • AdamF 88iS
                              • 2051
                              What are you guys talking about lowering the diff and compressing springs for the rears? I've done dozens of them and never had to do either. Disconnect the shocks and sway bar on both sides and use a little muscle to pop them in/out.
                              Adam Fogg- '88 M3
                              Common sense- It's the new 'gifted'
