Rear Spring installation
  • AndrewBird
    The Mad Scientist
    • 11897
    Originally posted by AdamF 88iS
    What are you guys talking about lowering the diff and compressing springs for the rears? I've done dozens of them and never had to do either. Disconnect the shocks and sway bar on both sides and use a little muscle to pop them in/out.
    That's what Josh and I did with his IE3's. I don't know why you guys are having so much trouble.
    • IS
      • Jul 2005
      • 366
      Ie3s are substantially shorter than stock springs. What you are "muscling" is actually your cv joints. Brilliant idea.
      87 325IS - Delphin Grey/Cardinal
      • Gus
        • Jan 2004
        • 285
        im with this guy
        i have H&R sports too....went in ridiculously easy. just disconnect sway bar and shock. stock springs are a wee bit of a bitch though i will agree. and as for CV's being muscled, you really think they are going to be affected by a couple of seconds of being at the limit of their range of movement?
        JUNGL3
        1990 "333i" Sport
        • Garageaholic
          Freestyle Fabricator
          • Dec 2005
          • 5204
          actually i didnt have my half shafts in. I put them in through the top hold first and finally snapped them into place on the bottom hole
          Recent Rebranding!!
          E30 SM62/S62
          E30 M60 V8
          E30 M30 Big 6!
          Instagram.com/garageaholic
          Youtube.com/garageaholic
          • AndrewBird
            The Mad Scientist
            • 11897
            Ditto, we did it the same way, but with halfshafts in. And we sure as hell didn't have to press hard enough that anything would happen to the halfshafts.
            • Garageaholic
              • Dec 2005
              • 5204
              how are your ears andrew?
              Recent Rebranding!!
              E30 SM62/S62
              E30 M60 V8
              E30 M30 Big 6!
              • AndrewBird
                The Mad Scientist
                • 11897
                Getting better every day. :)
                • BahnE30
                  • 1050
                  you think you "muscling" the CV joints is going to put more of a strain on them then driving. get a grip. there's over 2500 lbs of strain on them everytime you move the car
                  • 1991 318is
                    • Dec 2005
                    • 786
                    No problem here either.
                    Do all three of the following.
                    1) Jack up car with both rear wheels off the ground.
                    2) Disconnect shocks.
                    3) Disconnect sway bars from trailing arms.
                    There may be a little extra drag with new trailing arm bushings. I've done this three times.
                    • Garageaholic
                      • Dec 2005
                      • 5204
                      Yeah, but the drag on the trailing arms is all but null... if anything, the drag would be on the trailing arm tabs and maaaybe the subframe studs as the trailing arms hang down..
                      Recent Rebranding!!
                      E30 SM62/S62
                      E30 M60 V8
                      E30 M30 Big 6!
                      • arsevader
                        • May 2005
                        • 1025
                        It's not the amount of strain that's the problem. It's the fact that the CV joints aren't flexed in their normal position of movement.
                        No U-joint or CV likes to be have pressure placed on them outside of their normal range of movement. That's a fact.
                        • Garageaholic
                          • Dec 2005
                          • 5204
                          Yeah, I think that just about every guy on this forum would agree with you.. Everybody says that when you are removing your diff or anything like that, you MUST hang your half shafts by string or zip tie or watever...because naturally leaving them hanging will be outside of their normal range of movement, thus creating unnecessary stress
                          Recent Rebranding!!
                          E30 SM62/S62
                          E30 M60 V8
                          E30 M30 Big 6!
                          • AdamF 88iS
                            • 2051
                            As long as you don't turn them while hanging they are ok.
                            Adam Fogg- '88 M3
                            Common sense- It's the new 'gifted'
                            • AdironRider
                              • Dec 2004
                              • 3491
                              I pushed down on the brake/hub assembly a bit and my H&R OE sports slid right in.
                              Back to my roots
                              • BimmerTom
                                • 255
                                I'm going to have to disagree with the CV's being "stressed" when hanging down.
                                Running a CV at a severe angle (think of the front end of improperly lifted IFS trucks) will shorten the life of the CV, however.
                                The only problem I can see with hanging your CV's down is pulling at the CV boots. If they crack, they probably need to be replaced anyways.
                                FWIW, I just pulled out my rear springs by disconnecting the shocks, pulling out the sway bar (I'm replacing it) and a crowbar. Popped the springs right out.
                                Tom
                                My new blog site: http://www.tomperso.com
