GC coilover kit with HR race springs?
  • e30onBBSs
    • Dec 2014
    • 1347
    I'm doing some research about coilovers and I stumbled upon this. Is there an option to go with race springs? Is this kit stable? Once you select a spring brand can you ever change it?
    seems pretty freakin sweet!
    BMW tech
    Umass Amherst
    05 wrx sti
  • AndrewBird
    The Mad Scientist
    • 11898
    What exactly do you mean by "race springs"?
    • e30onBBSs
      • Dec 2014
      • 1347
      HR race springs, I just emailed GC but it seems like they would work with any spring, and GC would make the kit for those springs? Then I would just have to rebuild the front struts with the inserts right?
      BMW tech
      Umass Amherst
      05 wrx sti
      • Mr. Tasty
        • Jul 2011
        • 3421
        Race Springs refer to barrel springs. They are a linear spring rate, and not progressive like OEM rear springs.
        2014 Alpine White 335i MSport
        (Daily Driver)
        Full Mperformance Aero
        KW V2 Coilovers
        VRSF Catless Downpipes
        • AndrewBird
          The Mad Scientist
          • 11898
          No, they won't work with H&R Race. The adjusters only work with linear rate 2.5" springs. H&R Race are stock diameter springs.
          The kit you linked to includes new springs.
          • e30onBBSs
            • Dec 2014
            • 1347
            Are those springs bad for performance? Is Linear bad? What spring rate would I choose if I was mostly caring for performance? Like 7/10 performance 3/10 for comfort?
            Thanks guys! I'm going to research spring rates now too but if you know a good setup I really appreciate it =)
            BMW tech
            Umass Amherst
            05 wrx sti
            • Northern
              I like cupcakes & sh!tboxes
              • 5284
              Almost all coilover springs you'll see for e30s are linear rates. It just won't be as soft over small bumps.
              I'm running 450f/650R with the GE group buy kit that Nigel put together a few years back. Very similar to that GC conversion kit.
              Originally posted by priapism
              Originally posted by shameson
              • Mr. Tasty
                • Jul 2011
                • 3421
                This, progressive "stock-style" rear springs allow the spring rate to be softer, and when it loads up, stiffer. While the positives are that the car will be nicer when driven slowly, it is more unpredictable when tracking or hard driving.
                The linear rate "race" barrel springs have a constant spring rate no matter how much you load them up.
                (Daily Driver)
                KW V2 Coilovers
                • e30onBBSs
                  • Dec 2014
                  • 1347
                  Sounds good! What is the difference between these and coils then? With coils you can do dampening and such?
                  BMW tech
                  Umass Amherst
                  05 wrx sti
                  • Northern
                    • 5284
                    These are just the springs/perches/adjusters from their full coilover kit. They essentially are coilovers. You just don't get the konis (stock length or short), or camber plates.
                    • Mr. Tasty
                      • Jul 2011
                      • 3421
                      yes, he asked what the difference was between progressive spring designs and linear barrel designs.
                      (Daily Driver)
                      KW V2 Coilovers
                      • Mr. Tasty
                        • Jul 2011
                        • 3421
                        I think you are just all around confused. I have no where to even start with this question. Sorry dude.
                        (Daily Driver)
                        KW V2 Coilovers
                        • e30onBBSs
                          • Dec 2014
                          • 1347
                          I figured it out and it wasn't hard lol. Thanks for the help! Now I need to figure out the best spring rate to go with for a mostly street car..
                          BMW tech
                          Umass Amherst
                          05 wrx sti
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            Talk to GC. They are the experts on this and can help you get exactly what you want.
                            Also, SEARCH. Lots of discussion on this.
                            • e30onBBSs
                              • Dec 2014
                              • 1347
                              I'm searching, trying to decide whether or not to just send them the spring rates of the race springs.
                              BMW tech
                              Umass Amherst
                              05 wrx sti
