My GC/koni coilover set up just arrived. Were should I set the camber at. This is a street car on twisty roads, no track/autoX. The adjustable camber plates have just 4 lines on them not marked. The toe has a CL on it with 4 lines not marked. car is going to be low. Should I leave it the way they came. If someone could let me know were to set these at would be awesome. Any help would be appreciated.
GC coilovers
First of all, you don't adjust toe with the plates. That's done down below at the tie rods. GC race plates allow adjustment of camber and caster.
You will get a number of opinions, mine is to run 2 deg negative, which you won't be able to get if slammed on race plates, as they don't go positive. You gain about 1 degree of camber when you drop the car just 1", even on stock upper mounts.
...zero toe if you're just running around the streets, but driving in a spirited manner. Leave caster stock.
GCs Touring plates are a better choice for street use IMO as you can dial back the camber, and they're maintenance free.
