How do I decrease camber up front?
  • E30_Narek
    • Sep 2014
    • 398
    Hey everybody, pretty simple question (I hope). I'm running BC Racing coilovers on my car and they do have camber plates but even when I set the camber plates to the lowest setting there's still some apparent camber. Is there anything else I could do to fix this? It's not too much camber but I want it gone. Here is what it currently looks like.
  • efficient
    • Feb 2012
    • 3312
    You want positive camber, not negative camber.
    Negative camber is pushing the plates inwards toward the motor and positive is going outward towards the fenders.
    Take it to a alignment shop and tell them you want like -1 camber or zero but you might rub tire on fender
    • kronus
      • Apr 2008
      • 13032
      even at minimum negative camber settings on the plates it's going to have some negative camber due to being as low as it is, because the front suspension gains camber as it compresses or is lowered (up to a point).
      if you want less camber you're going to need to raise the car or get custom upper strut mounts.
      cars beep boop
      • E30_Narek
        • Sep 2014
        • 398
        I know how which way to push the plates. They were on opposite ends when I first installed the coils and the camber was ridiculous. Now, it's on the other end and it's much better but there's still a bit of camber left.
        So I can't take it to an alignment shop and have them align it for me like Efficient said?
        • kronus
          • Apr 2008
          • 13032
          if the camber is maxed out they won't be able to do anything more, no.
          cars beep boop
          • E30_Narek
            • Sep 2014
            • 398
            Ahh man. Well thanks anyways.
