Rhd conversion anyone?
  • Kyle_Splenda
    • Aug 2015
    • 13
    Hey I've been searching around for some info on a rhd conversion but haven't found too much. I have a clip with every single thing I need but I just wanted to see if anyone has come across any well documented write ups. Ive found out that:
    - the steering column bracket and glove box bracket just needs to be moved over. As well the hole pre-stamped in the firewall
    - pedal assembly welded
    - clutch reservoir moved
    - brake linkage setup
    - wiring should be easy as moving the rhd harness over
    - I believe the lhd hvac box fits fine as I would like to keep AC in the car.
    That's what I remember off the top of my head. If anyone knows any more info on this conversion please let me know. I might have to do a write up myself seeing as there isn't too much info.
  • agent
    Vice Grand Pubaa
    • 7960
    The FAQ/DIY section is for staff-approved instructional posts only. Please do not ask questions there. If you don't know where to ask your question, post it in General Technical and we'll move it to the appropriate subforum if necessary.
    Originally posted by kronus
    • stonea
      • 2890
      Theres already a DIY in the DIY section
      My Garage
      Feedback
      Instagram: Stone.Hopkins
