45mm vs 51 mm strut tubes?????
  • JRKOUPE
    • Dec 2004
    • 3159
    hey guys....
    selling some parts and want to be sure the buyer is doing it all proper.
    do all 318iS cars use 45mm frt strut housings?.....
    He wants my spare e30 6 cyl frt strut tubes...is that cool?....I don't know about 318is cars overall......
    edit.....I just read this:
    Only 84-85 318i and some 86-87 base model 325.
    is this true?...
    but I would imagine you could swap in 51 mm tubes to even an early 45mm car?......and use the proper inserts.
    __________________
    thnx!
  • efficient
    • Feb 2012
    • 3312
    If a dollar can wrap around the strut tube it's the 45mm. If it doesn't wrap around the tube it's a 51mm
    • ahrensNW
      • Mar 2015
      • 1716
      Yep, you're fun swapping strut housings. You hut the nail on the head. No 318is car has 45mm struts however.
      Hank Ahrens
      1984 Alpine Coupe
      1978 911sc
      • rav320uk
        • Jun 2004
        • 1337
        The difference visually for the struts are:-
        51 mm has the locking threads INSIDE the tube for the shock
        45 mm has the locking threads OUTSIDE the tube for the shock
        Easiest way to tel for someone unsure.
        If you have bought items from me, please leave feedback below.
        If you are a BUYER, Check My Feedback.:up:
        http://www.r3vlimited.com/board/showthread.php?t=183860
        Check out my Euro Build Thread
        http://www.r3vlimited.com/board/showthread.php?t=215557
        • jeffnhiscars
          • Jun 2011
          • 6011
          To make this even more confusing, you can install the smaller Bilstein sports in the 51 mm housing by buying the adaptor nut Bilstein sells. The valving is almost identical.
          Alice the Time Capsule
