GE coils
  • m42'd
    • Jan 2016
    • 37
    GE coils
    I have ge coil overs and bilstein sports, st front and rear bars, gc sp camber plates and poly all around. It's grippy but I have a feeling the hypercoil 450f and 650r are a bit much for the bilstein sports. What would be ideal? Send out my struts for custom valving or scrap and start fresh with a different coil over set up? Not really concerned with comfort, just flat out performance. Thanks.
  • Northern
    I like cupcakes & sh!tboxes
    • 5284
    Koni 8641 1021 Sport are perfect for those if you're keeping stock length struts. If you section them, go with 325ix konis.
    For rears, either the E30 part number koni sports (Which are compress to adjust) or if you want to ream out your rear shock mount hole out 1mm you can run the slightly stiffer/shorter/top adjustable mustang shocks (8041-1186 sport or 8041-1026 sport).
    Originally posted by priapism
    Originally posted by shameson
